Results 1 to 8 of 8
Thread: Control Arm Difference 1971 vs 1978
    I am keen to upgrade my ball joints, struts, bushings, tie rods, etc on my 71E and have found a pair of 78 SC control arms to buy.
    71 Left Control arm is 91134190100, 78 SC Control arm is 91134190101
    Does anyone know if I can use the 78 SC control arm in my 911 71E?
    My 911 is a daily driver so I would rather do all the work on a spare set of control arms and then fit them quickly on a weekend.
    Cheers,
    Paul
    Paul Rigg
    1971 911E
    Nelson Bay, NSW
    Australia
    Dec 2010
    Tulsa
    Likely it's the sway bar mount; lowboy on a '78, through -the -body on a '71.
    Jan 2011
    DFW TX
    Your '71 has pinch bolt ball joint attachment to the struts and the '78 was made for wedge bolt ball joints. I don't know if the two types of ball joints fit the control arms interchangeably.
    And the sway bar mount.
    Aug 2009
    SF Bay Area
    [QUOTE=M_deJong;651907]Your '71 has pinch bolt ball joint attachment to the struts and the '78 was made for wedge bolt ball joints. I don't know if the two types of ball joints fit the control arms interchangeably.
    The 2 arms are interchangeable. One just needs to install the proper ball joint to mate with the strut. The main differences (the sway bar link brackets) have already been stated.
    Jim
    Thanks guys. I would I assume I can simply remove and install the correct sway bar mount with a bit of grinding and welding. The used control arms look like they could do with a bit of a clean up and respray anyway.
    Again, appreciate your responses.
    Paul Rigg
    1971 911E
    Nelson Bay, NSW
    Australia
    Aug 2009
    SF Bay Area
    78 Vs 71 911
    Feb 2010
    San Francisco, CA
    Jim, if I'm not mistaken, those loops can be cut off and replaced with tabs:
    http://www.tarett.com/items/911-prod...dp2-detail.htm
    Is this the only difference?
    E911SR & RGRUPPE
    '73 S Coupe #306
    Aug 2009
    SF Bay Area
    Quote Originally Posted by kentf14 View Post
    Yup, that's about it
  1. FS: 1978 911 SC Parts
    By RTincher in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 11-02-2013, 11:16 AM
  2. MY 1971, The Difference in T and S Body Trim?
    By Stretch32 in forum Technical Info
    Last Post: 09-10-2013, 02:42 PM
  3. 1978-1989 Porsches
    By curtisaa in forum Other Porsche Passions
    Last Post: 01-14-2013, 01:46 AM
  4. Panoramas in binders 1969 1970 1971 1972 1973 1974 1975 1976 1977 1978 1979 1980
    By 88cs in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 06-09-2012, 12:45 PM
  5. 1978 Turbo
    By mjk911 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 09-01-2009, 08:30 AM
