Results 1 to 7 of 7
Thread: Paint Code Deciphering - Please Help!!
    Senior Member nvr2mny's Avatar
    Mar 2012
    Kansas City
    In searching the choices of "Green" (quite a lot more than I thought) I need help with two items;
    1) Our '69E has the paint code 6828 on the tag. The COA shows it as Golden Green and as a "special order" from the factory. The "traces" of the original color under the bright yellow re-spray indicate this. From searching this forum the paint code for Golden Green ('68) is 62165. Are they both right?
    2) I'm trying to find the paint, or formula, for this color so I can restore it back to it's original state color wise, plus I really love this color. Any ideas where to source the formula or the paint? I checked with Wilhoit and they don't offer a sample patch in this color.
    Any help is appreciated. Posted also in the Tech Forum.
    Oct 2008
    Burford, ON, Canada
    Yes, 6828 is the same as 62165. The 62165 is a Lesonal code while the 6828 is a standard 1968 code. I have seen some 6828-L codes and some 62165-L codes on the badges in about equal #'s. The -L on the badge indicates Lesonal as the supplier. So how they determined the code to put on the badge I don't know.
    Do a search on the codes and the color and find other members that have repainted their cars. Someone will have the info you require.
    Senior Member Carparc's Avatar
    Costa Mesa / Long Beach CA USA
    How quickly would you need your paint? I am about to start the restoration on a 911S 69 in Golden Green and will have the paint made from original sample from the inside of the door.
    Henk.
    Henk Baars owner of CarparcUSA LLC
    www.CarparcUSA.com
    www.911WoodDashRegistry.org
    S Registry #1490
    '68 911L Targa Sea Green
    '66 Volvo 123GT
    '62 Volvo P1800
    From the Glasurit site...
    PORSCHE 6828 GOLDGRUEN 1967-1968
    Glasurit Line 22 formula
    Base Amount Cumulative UNIT
    MC35 208.1 208.1 g
    M5 526.1 734.2 g
    M77 164.8 899.0 g
    M60 104.4 1003.3 g
    M68 54.9 1058.3 g
    M6 48.4 1106.7 g
    Glasurit Line 55 formula
    352-91 173.5 173.5 g
    M105 396.6 570.1 g
    M141 142.2 712.3 g
    M25 105.5 817.7 g
    M306 95.7 913.5 g
    A640 51.2 964.7 g
    A430 1.9 966.6 g
    Glasurit Line 90 formula
    M4 653.5 653.5 g
    A105 178.5 832.0 g
    A177 133.9 965.9 g
    A031 44.6 1010.5 g
    A306 28.7 1039.2 g
    A640 23.4 1062.6 g
    Peter Kane
    '72 911S Targa
    Mar 2012
    Kansas City
    WOW, I'm always amazed (and humbled) by the amount of information that is known - and shared on this board. Thank you ALL. This IS good news and such a cool color too!
    Port Macquarie, Australia
    Easily the nicest green of the era!
    John Forcier
    EarlyS #1987
    Restoration Saga
    Mar 2012
    Kansas City
    Henk, Sent you a pm.
  1. paint code help please
    By happytohaveone in forum General Info
    Last Post: 10-18-2019, 01:57 PM
  2. Paint Code Deciphering- Please Help!!
    By nvr2mny in forum Technical Info
    Last Post: 06-06-2013, 11:28 AM
  3. Wanted: paint code plate w/ Conda green code
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 11-05-2009, 07:33 PM
  4. how do I remove paint from paint code plate?
    By 911scfanatic in forum Technical Info
    Last Post: 10-26-2005, 06:00 AM
  5. Paint Code help
    By Paul in forum Technical Info
    Last Post: 06-20-2002, 03:42 PM
