Thread: Ahhhhhh eBay swayaway spring plate
    Jul 2012
    Kent, UK
    So I have won a spring plate described as swb, but when delivered it states 68-89.
    Can I use this? I'm guessing it will be the wrong length? Any pearls of wisdom here?
    Same deal with front and rear elephant racing poly bronze bushes. Damnit.
    Rich
    68 911S
    mbr. 2393
    I've cut them down to fit a SWB. not hard. SAW plate splines can be a real headache. for adjustability better to cut down a set of later factory spring plates.
    Dec 2008
    Black Mountain, NC
    Haycat911 has it right, the sway away unit can be difficult and the tab you adjust against just looks weak. stock LWB adjustable sets are very reasonably priced,
    ERP makes a stunning set of adjustable spring plates, but also more $$$
    If you have bushing sets for a 71 lwb, that is on my short list to upgrade the suspension on the 71 Targa, drop me a note.
  1. Spring plate removal
    By rick b in forum Technical Info
    Last Post: 03-16-2014, 09:47 AM
  2. spring plate question
    By Bob Harriman in forum General Info
    Last Post: 01-25-2014, 05:21 PM
  3. SWB spring plate /SC spring plates swap
    By smedley in forum Technical Info
    Last Post: 01-06-2014, 04:02 PM
  4. Spring plate adjustable
    By rapido in forum Technical Info
    Last Post: 11-29-2009, 06:08 AM
  5. NOS Spring Plate
    Last Post: 04-10-2009, 04:12 PM
