Thread: Question on Paint
    Question on Paint
    Can anyone shed some light on how the early 911 SWB were painted? Did they use a clear coat at the end to seal it off? I have sticker on it and when I tried to remove it with a blow driver some of the clear coat came off, but not the paint itself. I was always of the impression that the car was original paint on that part of the car but am being also told no clear coats were applied back in the days. So statements dont match
    many thx for any help
    TEE
    Registry Member #1869
    Senior Member Scotty B's Avatar
    Jul 2012
    Charles City Va
    clear coat was used back then but sparingly. Typically ONLY mettalics would been cleared. Either way, factory decals were applied after paint, so if there is one with clear over it, the car has definitely been repainted
    1973 911 RSR clone..... to be
    "And pretty soon you're grabbing gears like they are ten thousand dollar bills."
    http://www.kahikocustoms.com/auto-projects
    I didn't think they used clear at all back then. I'm not a certified Porsche historian, but I'd say that if your car has clear on it, it's been repainted.
    - Brian
    1966 Mercedes 250SE Cab
    thank you for the feedback. I am coming to the same conclusion
  1. Paint Code Question?
    By Torakki in forum General Info
    Last Post: 12-23-2011, 03:17 PM
  2. paint code mystery question
    By Buck Lewis in forum Technical Info
    Last Post: 04-15-2009, 02:03 PM
  3. Lesonal paint question
    By henrypoole in forum General Info
    Last Post: 03-21-2009, 09:54 PM
  4. 1967 paint question
    By goldsc78258 in forum Technical Info
    Last Post: 01-26-2008, 12:08 PM
  5. early 911 paint question
    By rickrick in forum General Info
    Last Post: 01-21-2005, 01:00 PM
