Results 1 to 10 of 11
Thread: four hole horn grills - original vs. repop...
    May 2011
    Chelsea, Québec
    Three questions for all the detail detectives on this board:
    (1) are there any distinguishing features/marks on original four hole horn grills that are not present on repops?
    (2) if not, how can one tell them apart? and
    (3) are these ones (http://www.ebay.com/itm/PORSCHE-1965...-/251277834751) a good buy at this price?
    Thanks!
    Member #1616
    I do know that if these are similar to later versions that rechroming is not very successful at all
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Stephen
    The four screw original horn grilles that I am familiar with are made from brass with a chrome finish. They weigh a pound or more each. The chrome gets foggy from road rash but they do not pit. Having them rechromed is very positive. The difficult part is the originals have deep machining and grinding marks into the corners - the rechroming surface prep blends (grinds/polishes) most of the imperfections out.
    There are numbers #1, 2 3 and 4 on the back sides of these originals. The first three are equal in visible marks in the corners. #4 has had more finishing and the vertical sides have a slight roundness and the chrome appears it may have been better, or the sample I have may have had less miles... Putting them together it's hard to tell them apart.
    (Not shown here) The second generation two screw grilles were cast from pot metal and pitted rapidly. Rechroming of the pot metal is not very successful.
    Filling all the pits is very difficult and If you miss any they stand out like face pimples on a first date. (And all the other pits that you didn't do on the underside reflect on the new surfaces- drat).
    Our friend in Seattle has recreated the two screw type - they are like his other products - the best you can get - but he mentioned he didn't have any luck trying to get the four screw type made. The quality was not to his satisfaction.
    Bob
    Early S Reg #370
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    If you can hold off on the ebay pair,I can send pictures of a set that I have, that are better & less costly..Don't know off hand about the scripting that Bob has disclosed, so I`ll have to check that out too.....Cliff......no time now, I`m on my way to work soon....
    I don't know about 4 screws, but when I had a number of 2 screw grilles, I noticed that the slats, where they ended on the outside, some ended abruptly, with a straight cut. Others seemed to be filed or rounded for a more flowing ending. If that makes sense.
    May 2011
    Chelsea, Québec
    Thanks for the great info, Bob and others... very helpful to understand all the details of these wonderful cars...
    Member #1616
    Quote Originally Posted by Bobs 67S View Post
    The numbers 1,2,3 and 4 refer to the size. #4 is the largest.
    On the picture #2 on top of #4
    Just my $.02
    Richard
    That is a really good piece of information, Richard..
    thank you. (I'm making notes...)
    I love saying it "the more we look - the more we see".
    Bob
    Early S Reg #370
    The key to rechroming two-screw grilles is to scour the globe for the nicest, most pristine set you can find, nice enough that you could polish them and use them. Then have those rechromed!
    The "Seattle Stuff" is better than new. As for re-chroming I didn't have any luck and did use PAUL'S CHROME PLATING. They are around here somewhere but are totally FUBAR. Don't know if the "The King of Trim" (a nick-name I would liked to have had in college) can do any better but it may be worth a try.
    Tom
    Early S Registry #235
    rgruppe #111
  1. FS: 4-Hole Horn Grills
    By rcnagel in forum For Sale: 911 Parts
    Last Post: 07-05-2012, 01:45 PM
  2. FS 4 hole horn grills
    By fishman7 in forum For Sale: 911 Parts
    Last Post: 04-09-2011, 08:31 AM
  3. FS: SWB horn grills (two hole)
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 08-18-2010, 08:16 AM
  4. FS: 4 hole horn grills
    By kenikh in forum For Sale: 911 Parts
    Last Post: 03-01-2007, 01:22 PM
  5. FS: 4 hole horn grills on Ebay
    By hdavis in forum For Sale: 911 Parts
    Last Post: 09-04-2006, 09:52 AM
