Hi All,
My Fuel / Oil Gauge has two things I can't seem to sort out.
1: The fuel gauge low level warning light is always on regardless of the tank level. The level gauge works as it should.
2: The oil level gauge is beyond the maximum reading all the time.
When I disconnect the leads at the oil level sending unit the gauge is still pinned to the top.
When I disconnect the green/white from the back side of the oil level gauge it still pinned to the top.
The only connection I need to the gauge to max out the oil level is the positive and the ground.
This makes me wonder if the gauge is bad?
If any electrical folks might be able to lend some guidance it would be appreciated.
Thanks in advance.
Bob
