Results 21 to 30 of 37
Thread: My Current 1971 911T Hot rod build.
  1. #21
    Senior Member Fubawu's Avatar
    May 2013
    Well I have made some more progress,
    -Engine was pulled and valve cover gaskets replaced (no more leaks)
    -Banana Arms replaced
    -Trunk area cleaned up all wiring/battery moved to smugglers box.
    -Alignment completed
    -Interior pieces added, Rennline
    -Rennshift 901 shifter added (still needs tweaking as 1st to 2nd is a bit tough)
    -Braile battery installed only 11lbs
    -Fan and shroud painted
    -All engine bay pieces painted/cleaned
    -Weltmeister 22mm rear sway bar
    -Turbo Front swaybar installed
    -15x7 Fuchs on BF Goodrich R1's 205/50/15
    I know I am missing a few more details, next up new seats, harnesses, and steering wheel.I also have RS door cards with custom houndstooth fabric in the works!
    Name:  Porsche side wheel.jpg
Size:  154.4 KBName:  Porsche interior.jpg
Size:  90.8 KBName:  Porsche interior driver.jpg
Size:  110.6 KBName:  Porsche engine bay Sept.jpg
Size:  73.5 KBName:  Porsche Frunk Sept.jpg
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  2. #22
    Senior Member Peanut's Avatar
    Aug 2012
    Florida
    So did you paint the Fuchs black again? Can't really tell from the pic you posted. They looked great in your RSR style in your earlier posts. I have the same Braille battery in my car. It has worked out well, and it IS light.
    1968 911S
    1986 Carrera
    2006 Carrera S
  3. #23
    May 2013
    Good eye! Those are different Fuch's on the car 15x7 all black centers
    On another note I am pulling the interior over the winter and having it resprayed half cage installed etc.
    Everything takes so much more time then you think!
    Fan has been refinshed with high temp paint
    Name:  fan housing 911.jpg
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  4. #24
    May 2013
    Time for a little update:
    I have managed to strip out the interior as I am painting the interior to give it a more raw "finished look".
    While I was in the process I thought I would refinish the trunk and gas tank to match the qaulity of the rest of the car.
    As most of you know it takes a lot of time to complete. I thought I could get this done in a month but like everything I do
    with this car it has taken double that. Here are some of the pics of the progress. Once the paint is done I am going to
    install new seats harnesses etc.
    Before and Mid way completed
    Name:  911 TRUNK BEFORE.jpg
Size:  101.3 KBName:  Porsche trunk stripped.jpg
    The interior has been a lot of work. Harsh chemicals and tight spaces....reminds me of college
    Name:  911 stripped interior.jpg
Size:  103.3 KBName:  911 pass stripped interior.jpg
    Laying out everything to pick decal colors as well as paint
    Name:  911 colors.jpg
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  5. #25
    May 2013
    Once I got everything out of the interior I was surprised how clean the metal work was. No major rust
    to speak of only a couple surface areas that needed a touch up
    Name:  911 DIRTY.jpg
Size:  115.9 KBName:  911 rEAR SEAT STRIPPED.jpg
    Each of my 3 kids has helped with this build!
    Here is everything prepped for paint
    Name:  porsche interior stripped.jpg
Size:  22.0 KBName:  Porsche rear interior.jpg
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  6. #26
    May 2013
    Here are a few of the before pics:
    Plans are to install Euro lights and chrome trim for the rest of the turn signals. Chrome Horn grills,
    Porsche Decals side and rear, Talbot Drivers mirror. The 993 mirrors have been turffed!
    Going with a Dansk RSR exhaust and a few other small touches Interior is going to be a minimalist approach.
    Name:  Porsche parked!.jpg
Size:  23.7 KBName:  Porsche interior.jpg
Size:  90.8 KBName:  Porsche engine bay Sept.jpg
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  7. #27
    May 2013
    Getting there, maybe another 80 man hours to go
Size:  100.1 KB Name:  9447_820534021306713_93746766_n.jpg
Size:  116.7 KBName:  1653362_820517204641728_2095168248_n.jpg
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  8. #28
    looks great!
    Early 911 S Registry #2701
    930 powered 1973 911T
  9. #29
    May 2013
    Well time for another update. Car is back in my garage and most of my time has gone to completing the interior.
    Name:  Porsche rear seat area.jpg
Size:  140.7 KBName:  Porsche door card.jpg
    I ordered my brackets seat brackets from Wedge and they were well made other then the fact the holes did not match up
    to my OMP seats. This added a few hours of work as measurments and grinding had to take place. I wasn't a too pleased
    about this as the only reason I bought them was to save me making my own. Seats are in and all is well
    Name:  Porsche seats in.jpg
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  10. #30
    May 2013
    After getting most of the interior bolted in I took the car over
    to a friends shop to complete the trailing arms (again) as well as
    replace the bushings and wheel bearings.
    Suspension was bolted bolted and given a good cleaning!
    Name:  Porsche rear trailing arms.jpg
Size:  11.2 KBName:  Porsche front suspension.jpg
    Next items on the list alignment, Dansk muffler install. Need to lengthen the mid pipe as it
    does not reach the Dansk muffler. I found out the hard way after install!! Lastly finish
    the interior and a good cleaning. Hershey is just around the corner!!
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  1. 1970 911T Light Weight Build
    By CaryPhotography in forum General Info
    Last Post: 06-08-2017, 09:50 AM
  2. Another 1973.5 911T Build Date Question
    By SJN901 in forum General Info
    Last Post: 02-12-2014, 04:47 AM
  3. 1971 - location of fuel pump/build date question
    By Sean F in forum General Info
    Last Post: 10-17-2013, 07:48 AM
  4. 911T Karman build
    By Julia in forum General Info
    Last Post: 02-24-2004, 02:43 PM
