Results 1 to 10 of 11
Thread: JE & Carrillo: inside contact urgently needed!
    Jul 2003
    Vienna, St. Gallen, Stuttgart
    Gentlemen,
    my dear engine broke a Carrillo con rod, smashing basically the whole longblock, crank etc. We could not determine any mechanical wear or defect that could be the likely cause of the con rod failure.
    Since I run custom JE pistons I need an inside contact at Jerry Woods who would be in a position to check how fast I can get a replacement piston.
    Also, I would like to get a similar contact at Carrillo to discuss possible reasons for the fracture and how I should proceed.
    Thank you for your help!
    Keep up the speed!
    Anatol
    '68 911S coupe
    '92 964 RS NGT
    '09 987S Boxster
    Feb 2010
    San Francisco, CA
    Have you tried Rich Walton @ Jerry Woods?
    Rich Walton Rich@jerrywoods.com
    or, you can try the man himself.
    Jerry Woods Jerry@jerrywoods.com
    Good luck and sorry to hear of your loss.
    E911SR & RGRUPPE
    '73 S Coupe #306
    Jul 2003
    Kent, thank you for your help!
    Keep up the speed!
    Anatol
    '68 911S coupe
    '92 964 RS NGT
    '09 987S Boxster
    Senior Member C.Plavan's Avatar
    Mar 2005
    Clovis, Ca
    We have seen this before in the vintage racing community. Now most guys only use Pauter rods.
    Chad
    911ST Race Car w/2.5L SS race motor.
    1972 911 T- Original numbers car- restoring it
    2016 Elan NP01 Prototype Chassis #20; Car Number #02
    2011 Porsche Spyder Wht/Blk/ Carbon Fiber Buckets (Sold)
    Powered by Faragallah (Aase Motors)
    Not that I doubt you Chad, but I've always considered Carillos to be the gold standard! Now you tell me they break!!! Does it take extraordinary RPM or what IS the cause??
    Mar 2005
    Clovis, Ca
    A racer friend had the same thing happen to his 2.0L race motor with Carrillo rods. Early to mid 2000's. We have not used them since. Not sure what the cause, but it was the rod- not an oiling issue if I remember correctly.
    Edit- My DAD had one fail also on his 2-liter.
    Chad
    Dec 2008
    Woodland Hills, CA
    Doesn't Carrillo have a guarantee that their Rods will not break? At least they did when I ran them in my race motors.
    Mar 2005
    Clovis, Ca
    Quote Originally Posted by gsjohnson View Post
    Would you give them another chance after destroying a race motor? Not me
    Chad
    Dec 2008
    Woodland Hills, CA
    All the vintage Trans Am guys running 500 plus hp run their rods with no failures. I also have never had their Rods fail on me either. Usually there's a underlying reason for the failure. Not saying that a Carrillo Rod couldn't fail, but I find it unusual if they did. I would think that they would go under having to guarantee all of these supposed failures...
    Jul 2003
    I was really devastated that a Carrillo could break in normal road driving use. I never tracked the car, I never drove with revs beyond 7500 rpm. We could not find traces of oiling issues. The issue occured after 11,000 km / 3 years: all warranties void, whole damage hits my bank account...
    My engine builder also leans towards Pauter rods for the rebuild. I will try and contact Carrillo to hear what they suggest.
    Keep up the speed!
    Anatol
    '68 911S coupe
    '92 964 RS NGT
    '09 987S Boxster
  1. WTB: Urgently needed LHS heater control valve in trunk
    By murph2309 in forum For Sale: 911 Parts
    Last Post: 03-22-2014, 08:00 AM
  2. WTB 1968 sunroof parts urgently needed!
    By 911r67 in forum For Sale: 911 Parts
    Last Post: 04-22-2012, 07:34 PM
  3. Needed fairly urgently - Early 911 rear wheel bearing retainer
    Last Post: 02-13-2011, 12:21 PM
  4. Replies: 1
    Last Post: 05-19-2008, 09:07 AM
  5. Details for 2.4E needed urgently.
    By 72911E in forum Technical Info
    Last Post: 01-17-2007, 02:02 AM
