Results 1 to 10 of 10
Thread: Engine Cooling Fan & Houseing cleaning Technic?
    I have a 11 blade fan, the casting on it as we all know it its not very good, I have tried to soda basted the fan and the housing to get a good finish but Ian not 100% convince. I am looking for a OEM look and don't want to pait them. its there a quimical product or something that will be recommended for this magnesium cleaning?
    Senior Member maspirito's Avatar
    Jan 2013
    lexington,kentucky
    Search on pelican There is a long Thread on this subject
    Feb 2010
    San Francisco, CA
    As I recall, the pelican thread is pretty good. Most people looking for an original mag finish will agree that applying Gibbs penetrating oil will maintain a good look and allow the mag to eventually mellow to the aged grey color.
    I had my fan and housing glass beaded followed by a coating of Gibbs.
    Here's what it looked like after it was done. It's still about the same color and has been over a year since completed.
    E911SR & RGRUPPE
    '73 S Coupe #306
    Now we are talking!! Looks great
    Thank You.
    May 2006
    CT
    I bead blast the fan with the hub masked and then spray with metal etch to bring out the oxidized mag finish. Final spray with Gibbs or CorrosionX.
    This process works nicely on all mag parts to restore the original finish.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Feb 2010
    San Francisco, CA
    Masking off the hub is a good way to go. I wish I had dine this to mine.
    E911SR & RGRUPPE
    '73 S Coupe #306
    Nov 2006
    S. F. Bay Area
    Quote Originally Posted by tom1394racing View Post
    any particular metal etch?
    Brian
    S Reg #1032
    Dec 2008
    Woodland Hills, CA
    Be careful, the early fans are magnesium so I would be careful with the media that you select.
    May 2006
    CT
    I always use 80 grit glass bead at about 80 PSI and POR-15 Metal Ready.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Hi, we take the centre out, the media clean and chromate. Then refit a new centre that we make and re - revit. A bit over kill maybe.
    HTH
    Alan
  1. Engine cleaning tips
    By Norm01 in forum Technical Info
    Last Post: 04-17-2014, 03:11 PM
  2. FS: Engine Cylinder Cooling Tins
    By m1franck in forum For Sale: 911 Parts
    Last Post: 09-25-2013, 02:38 PM
  3. 1992 BMW M-Technic Convertible
    By dskeller in forum Other Car Cultures
    Last Post: 07-09-2012, 07:12 AM
  4. Engine cooling tins
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 01-15-2012, 08:03 AM
  5. Cleaning that engine bay...
    By Kaleid in forum Technical Info
    Last Post: 04-20-2007, 05:09 PM
