Thread: Cleaning external cooler hard lines ...
    Apr 2011
    N.Calif., south of SF
    Bought a used external cooler setup for the 73S. Any suggestions on cleaning the tubing internally?
    Unsure of how long the donor car was inop.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Jan 2011
    DFW TX
    I was recommended to use foaming Gunk followed by a hot water flush. This worked pretty well. I have also used mineral spirits with capped ends and a soak/slosh/soak method. When done hang them up for a while to drain.
    For the outside I used stainless steel pot scrubber mesh and mineral spirits. Wurth self etching primer and a light coat of black Krylon. Bare is ok, but black stays nice looking longer imho and doesn't hurt the heat dissipation.
    You are going to like the lower oil temps, and the higher oil pressure that comes with the package. And you gain a couple of quarts of oil which helps everything some more...
    Mike
    Apr 2011
    Thanks for the cleaning suggestions. I like the clean look of the black lines, low maintenance (and potential heat dissipation).
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Oct 2005
    wash dc/ los angeles ca
    Compressed air is your friend...'nuff said!
  1. 911 S without external oil cooler/lines ?????
    By J.Puppi in forum Technical Info
    Last Post: 05-14-2015, 10:12 AM
  2. PRE-74 Elephant Racing Oil Lines - Rocker Hard Lines to Cooler
    Last Post: 11-07-2012, 10:58 AM
  3. Replies: 5
    Last Post: 02-02-2009, 02:23 PM
  4. WTB: 73 Hard Front Cooler Lines
    By rick2 in forum For Sale: 911 Parts
    Last Post: 03-01-2006, 05:48 PM
  5. Replies: 18
    Last Post: 07-14-2005, 07:32 AM
