Results 1 to 10 of 15
Thread: K & N filters
    Senior Member Merv's Avatar
    Jan 2013
    Queensland, Australia
    K & N filters
    I can't seem to locate a thread that answers many questions about the use of these filters in rain hat housings. I have a carb motor with rain hats and True Flow foam filters. I like the induction noise but wondered if the K&N ones are better. Are the K & N ones even suitable for early (non-MFI) 911s?
    I am interested in the K&N part numbers and any info on experience with these.
    Merv
    Member # 2633
    Cars:
    Porsche '68 - 911N (Sold)
    Porsche 356B (T-6) S Coupe
    Porsche 2010 Gen.2 Boxster S
    Having owned a few newer diesel pickups and still owning an auto parts store, my conclusion on K&N is that they're not as good as a paper filter when both are new, but they're better than a paper filter when both are dirty. Therefore, I buy paper filters and replace them before they need replacing.
    My opinion.
    - Brian
    1966 Mercedes 250SE Cab
    Quote Originally Posted by Merv View Post
    K&N makes a specific air filter for the above filter housings. Check Pelican Parts, Pegasus Racing, Paragon Porsche and others.
    Foam is good, but it tends to deteriorate after awhile.
    Paper is better and cheaper if you can find the correct size. I'll attempt a follow up with some part numbers from another computer.
    Sherwood
    Port Macquarie, Australia
    Merv, I think there are paper filters on the K&N filters that came with the two engnes I've just bought. I'll try and find you a part number... might have to be the weekend though.
    John Forcier
    EarlyS #1987
    Restoration Saga
    Jan 2013
    Thanks that would be helpful. The K&N catelogue is a long one. Ican see one on PP but it appears to be round not oval. That may of course be still correct.
    Merv
    Member # 2633
    Cars:
    Here's the info on paper filters for the K&N Water Shield/Filtron-type filter housings:
    Fram CA192
    STP SA192
    Wix 42088
    Purolator A30067
    http://forums.pelicanparts.com/porsc...ml#post7069681
    also:
    AC-Delco A178CW
    AC-Delco A178CWK
    All about $5.00
    Delco A333c (uses a poly wrap around the OD).
    Also:
    Amsoil EA Air Filter, EAA32, $30
    http://www.performanceoilcompany.com...filters-EAA32/
    .... and the original K&N cotton-gauze filter specs: K&N Part E-3670 Product Specifications
    Product Style: Round Air Filter Height: 3.25 in (83 mm) Inner Wire: No Inside Diameter: 8.375 in (213 mm) Outside Diameter: 9.625 in (244 mm) Top Style: Open Top Material/Finish: None Filter Material: Cotton Gauze Filter Re-Oiling Amount: 1.1 oz (33 ml) Weight: 1.3 lb (0.6 kg) Product Box Length: 10.19 in (259 mm) Product Box Width: 3.94 in (100 mm) Product Box Height: 10.31 in (262 mm)
    Hope this helps,
    Sherwood
    Jan 2013
    Brilliant thanks Sherwood. These are the filter housings that I have. I assume that several of the filters you list should fit, as they seem to be common housings? From what I can see the K&N ones require a K&N housing. I am not at home now so can't measure.
    Merv
    Merv
    Member # 2633
    Cars:
    Merv
    Merv,
    The filter housings on your engine are made by K&N and are built around their E-3670 filter.
    Jan 2013
    Thanks again Sherwood. They are round but will fit into the oval housing from what you are saying?
    Merv
    Merv
    Member # 2633
    Cars:
    Merv
    Yes. Bend to fit...... the filter.
  1. Replies: 1
    Last Post: 04-01-2014, 05:36 PM
  2. FS/T: '65-'71 Oil Filters
    By PCA7GGR in forum For Sale: 911 Parts
    Last Post: 01-06-2010, 06:28 PM
  3. Oil Filters; Are They Different?
    By Peter Aziz in forum General Info
    Last Post: 10-12-2005, 06:05 PM
  4. air filters for MFI
    By targa911s in forum Technical Info
    Last Post: 06-17-2002, 08:56 AM
