Results 1 to 10 of 11
Thread: 73 S - best resources for parts???
    While I have yet to do an inventory of the many boxes of parts that came with my 'S' (heading off to the Porsche Parade tomorrow), I know I'll discover items that I want to replace because of wear or condition. Since many on this forum have already faced this challenge, I'd appreciate hearing thoughts on the best sources for OEM items (and reproductions where OEM items are NLA), as well as any sellers of used items who have proven to be good guys with quality items. Thank you!
    Dec 2003
    West Los Angeles
    That's a good list.
    Keep in mind, most of these sellers of new "OE" parts are dealing with a handful of reproduction parts makers. So a not-quite-right part from one is likely going to match a not-quite-right part from another. You need to be able to return unsatisfactory parts.
    Most recently there have been complaints about the replacement '69-73 inside door handles. The molding is very low quality.
    We need to collectively reject these "OE" parts that are substandard.
    EDIT: sorry, missed a really excellent source: http://www.autoforeignservices.com
    techweenie.com
    Salvage as much as you can, AND DON"T THROW ANYTHING AWAY !!!
    Feb 2010
    San Francisco, CA
    +1
    Since many of the "OEM" replacement parts are either different, or just don't match the quality of the '73 original parts (case in point, new OEM MFI fuel pump), you'll want to reuse/restore/revitalize as much of the original gear as possible.
    For things that simply must be replaced, or a are missing, you'll want to stock up on patience. Trolling the forums (like this one) will yield much of what you need.
    Also, in addition to EASY mentioned above, try http://www.partsheaven.com/Default.asp
    Have fun @ the parade.
    E911SR & RGRUPPE
    '73 S Coupe #306
    Dec 2003
    West Los Angeles
    Quote Originally Posted by kentf14 View Post
    ...you'll want to stock up on patience.
    Boy howdy.
    techweenie.com
    May 2005
    Oroville, CA
    As Eminence noted OEM is not the same as OE.....Many parts were made by the manufacturers that weren't used on production cars but were aftermarket (i.e. Cibie, Bosch etc). Terms are very important when describing a part.
    Spend the time and research the part here first.
    H
    Senior Member platas's Avatar
    Jun 2005
    Spain/Houston
    Boy David thats the truth.
    San
    53 Pre A, 65 356
    70 914/6 GT
    65 912, 67 911
    71 911 Targa,72 E Tara, 73 911 Targa
    70 911 S,71 911 S,70 911 T,
    71 911 T, 72 911 E ,73 911 T
    74 911 Coupe
    74 911 Targa
    1972 RennSport Bus
    Early Reg # 771
    Senior Member Scotty B's Avatar
    Jul 2012
    Charles City Va
    1973 911 RSR clone..... to be
    "And pretty soon you're grabbing gears like they are ten thousand dollar bills."
    http://www.kahikocustoms.com/auto-projects
    Jan 2003
    NW Indiana
    Ron's business Aase Sales has good stuff also.
    http://www.aasesales.com/
    Brian
    '71T
    R Gruppe #299
  1. Replies: 16
    Last Post: 12-13-2012, 09:44 AM
  2. Replies: 0
    Last Post: 12-05-2010, 01:00 PM
  3. Production numbers resources?
    By kenikh in forum General Info
    Last Post: 11-02-2005, 11:53 AM
  4. throttle body - mfi resources
    By racemor in forum General Info
    Last Post: 03-21-2005, 09:44 AM
  5. New and Looking for help & resources
    By cpc3090 in forum Technical Info
    Last Post: 07-01-2003, 04:00 AM
