Results 1 to 9 of 9
Thread: WTB: External oil cooler components correct for 73 911S
    Apr 2011
    N.Calif., south of SF
    I am looking for correct pieces for an external oil cooler for a 73 S. I know that some of the pieces are still available from Porsche. Especially looking for 73 S/RS loop/trombone, hard lines and regulating housing.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Feb 2007
    San Diego
    sent you a pm with a place to get some of those parts
    Apr 2011
    Thanks Mark
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    You can buy everything except the trombone cooler from porsche. And you can buy the later style trombone cooler which can be modified to be like the 73 style. You just need to shorten the inlet pipes and silver solder on new fittings. Also make and solder on mounting brackets.
    Apr 2011
    I was aware of a lot of the 73 specific parts available but expand on the:
    if you would please.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    as far as I know the trombone was 1 year only 73. same for thermostat on oil tank and the different lines to match.
    alan in the uk has perfect copies of the trombone.
    Apr 2011
    David. Just looked at his site. Ideally, of course, I would like to find these with "previous experience" (used). Good to know.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    In case a pic helps. Here is one of ours just fitted on one of our current restos.
    HTH
    Alan
    Apr 2011
    Nice work Alan.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  1. 911 S without external oil cooler/lines ?????
    By J.Puppi in forum Technical Info
    Last Post: 05-14-2015, 10:12 AM
  2. Need help with 28 Row external oil cooler tab
    By Haasman in forum Technical Info
    Last Post: 07-15-2013, 01:32 PM
  3. Cleaning external cooler hard lines ...
    Last Post: 06-18-2013, 09:40 PM
  4. FS: External Oil Cooler Mounting Hardware
    Last Post: 08-14-2005, 03:35 PM
  5. DIY install of external oil cooler questions...
    By bob tilton in forum General Info
    Last Post: 06-02-2005, 09:20 PM
