Thread: 73S- Adjusting for clutch free play and ...
    Apr 2011
    N.Calif., south of SF
    I found the inner adjusting nut is almost all the way to the inner end of the cable ... does this mean needs new clutch? Stretched clutch cable?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Apr 2011
    Anyone have an opinion?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    May 2005
    Oroville, CA
    You are on the right track. Before changing the clutch look at the other stuff. The arm at the clutch pedal end goes bad at the hook and like you said, the cable. Also look at the bowden tube and the other mounts by the trans. Hopefully it is a cable, they are the best to change out of the lot.
    H
    Apr 2011
    Thanks Harvey. That's the way I'm thinking. Stretched cable? No problem .... I'll take one of those any day-
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  1. Adjusting Carbs - solex
    By vintage83 in forum Technical Info
    Last Post: 06-12-2008, 05:14 PM
  2. Weber air adjusting screw set up
    By cosley in forum Technical Info
    Last Post: 09-27-2006, 02:28 AM
  3. Adjusting Koni Struts
    By CurtEgerer in forum Technical Info
    Last Post: 04-27-2006, 05:25 AM
  4. Adjusting Webers
    Last Post: 07-04-2004, 07:00 AM
