Results 1 to 2 of 2
Thread: FS: 2.7 RS spec motor and 915
    Hello,
    I have for sale a near new 2.7L RS build motor with run in time only that came out of an aborted RS project. The engine had a lot of money thrown at it. The 915 box shifted well when it was driven shortly before being pulled, and is an SC vintage. I will sell as a package at $10k or seperate the two. A quiaff 915 diff is also avaiable for an extra cost. Here are the spec's on the engine. Engine is located in Southern California. I would prefer pick up, but we can discuss. Email me with any interest...Steve atomicpunk@roadrunner.com
    Case:7R, align bored .25, shuffle pinned, oil by pass modification, releived for 3.3L oil pump. New 3.3L oil pump, new Glyco main, rod, and intermediateshaft bearings, new endless timing chains, new ramps.
    Crank:Std/Std, magnifluxed, micro polished, balanced
    Rods: Original 2.7 rods, APR rod bolts, magnifluxed, polished, shotpeened, resized big end, new pin bushings small end, balanced end to end, & total weight.
    Pistons: J&E forged 10.5-1, lightweight wrist pins, new Goetz rings, Nikisil Mahle cylinders
    Heads: 2.7L, smog holes welded closed, ported/polished intake/exhaust ports, polished chambers, surfaced, all new guides, Aasco titamium retainers, Aasco competition valve springs, teflon valve stem seals, new exhaust studs with time certs, new Web 2021 Cams, new rocker arms.
    Additional items: New PMO carbs & manifolds, K&N watersheds, 11 blade fan, turbo lowers, Carrera tensioners, resurfaced flywheel, new flywheel bolts, MSD AL6 ignition, Nology hot wires, New Sachs clutch.
    1969 911 E #824
    Jul 2009
    Hamilton, New Zealand
    PM sent
    Cheers
  1. WTB 2.7 RS Spec Motor
    By Todsimpson in forum For Sale: 911 Parts
    Last Post: 08-11-2011, 02:45 PM
  2. 2.4 ``S`` spec motor for sale
    By Francois Duval in forum For Sale: 911 Parts
    Last Post: 08-24-2007, 11:24 AM
  3. 1972 911T with 2.7RS spec motor
    By flatspin911 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 05-19-2007, 04:21 PM
  4. 69T with 2.2S spec Motor
    By gruen911 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 06-04-2006, 07:10 AM
  5. New Life with the 2.7 RS spec motor
    Last Post: 06-02-2004, 11:27 AM
