The 'search' results were inconclusive (and a tad dated): Is anyone (other than a salvage yard) supplying correctly marked and sized fender fasteners? Thanks
Brian
S Reg #1032
Really? I can't be the only one.....
Brian
S Reg #1032
Yeah, I met that guy June 1st, we actually have T & M Greene/Automotion in our common past. I may see him soon for a bunch of other stuff that he may not have any more of too! See you soon.
I guess I'll use the aftermarket screws, collect and refinish enough originals, and then carefully replace them 1 by 1...
Brian
S Reg #1032
Kamax or NSF for sure...maybe Karro or Verbus
Off the floor at Jim's place!
Mark Smedley
'59 VW Typ I
'69 911T 2.7
'86 930
'04 GT3
'16 Boxster GTS
64-67 (and maybe 68) use a rectangular washer under the bolt head, all later models use a round washer.
My '67S also had gasket material the same dimension as the rectangular washer
under the washer next to the fender flange.
By "fender fasteners" do you mean the self taping hex head screws?
If so those were marked with a "K" on the head, for KAMAX, followed by the rectangular washer and then t
Mark Smedley
'59 VW Typ I
'69 911T 2.7
'86 930
'04 GT3
'16 Boxster GTS
My 66 has the Rectangular washers. Not sure about the head markings. From memory mine are blank/smooth. My car was produced in 65 if it matters.
Mark Erbesfield
1973 911S #9113301282
1957 356A #58648
1982 Toyota Land Cruiser FJ40
1977 Toyota Land Cruiser FJ40
1979 MB 450SL "Dad's old car"
2019 Cayenne "Wife's car"
