Results 1 to 9 of 9
Thread: What is the correct color 73.5 2.4 engine
    My engine is getting a full overhaul done on it. I'm looking for a few correct ( factory) colors or disarible colors on
    Engine shroud
    Valve cover
    Engine tin
    Engine cover
    Engine compartment
    Aug 2011
    New York
    Engine shroud came in either Yellow or Black. http://forums.pelicanparts.com/porsc...-73-5-cis.html
    The engine compartment is body color.
    E Sully
    1973.5 911T
    Aug 2009
    SF Bay Area
    Quote Originally Posted by ESully View Post
    Don't put much stock in that thread! The factory painted yellow fan shrouds black for CIS cars. One poster claimed that a PO painted his fan shroud. That was an assumption on his part and is probably wrong.
    CIS 73.5 Ts had black fan shrouds. I suppose there could be a couple exceptions, though.
    Jim
    I seen a few concourse restoration on some 73.5 & some had the yellow some had the black ! I just wasn't sure if the yellow was a factory option or just some one thought that it looks cool ! Thanks guys great info ! Learn something new everyday on this forum !
    Aug 2009
    SF Bay Area
    Quote Originally Posted by LV911 View Post
    All 2.4 72 and early 73 Ts had yellow fan shrouds that were changed to black with the 73.5 CIS Ts. If you look at non-concours cars you will probably see yellow showing through cracks and gouges in black fan housings on 73.5 Ts.
    Jim
    Feb 2010
    San Francisco, CA
    For your reading enjoyment LV911
    http://www.early911sregistry.org/for...-Shroud-Colors
    http://www.early911sregistry.org/for...-Engine-Shroud
    Quote from post #11 "Early CIS cars had yellow shrouds that the factory painted black."
    E911SR & RGRUPPE
    '73 S Coupe #306
    Senior Member mohrgan's Avatar
    May 2011
    Upstate NY
    On my 73.5 T, it was painted black from the factory and stripped to yellow gelcoat during the engine rebuild process.
    -Chris Mohr
    S Registry #1978
    Agree with posters above, on my all original, motor never out 73.5 it had a yellow shroud painted (quite poorly painted) black so lots of yellow poking out on the corners, etc.
    Factory correct isn't always beautiful...
    1973.5 'T' Reference Car
    Here's a thread . . .
    http://www.early911sregistry.org/for...grats-to-Kent-!!!!!!!!!
    Not a lot of pictures --- so, you might try pinging some of the members that contributed
    Apparently, last sold in Germany
    VIN = 9113102403
  1. Replies: 3
    Last Post: 01-08-2013, 05:29 PM
  2. Correct texture and color?
    By FL-Frank in forum General Info
    Last Post: 07-05-2011, 01:17 PM
  3. Correct color for TTG LWB brackets
    By pu911rsr in forum Technical Info
    Last Post: 07-23-2009, 08:26 PM
  4. My 69 E targa, correct color?
    By teveo in forum General Info
    Last Post: 05-25-2009, 10:59 AM
  5. Correct color for undercoating
    Last Post: 11-16-2006, 10:38 AM
