Results 1 to 9 of 9
Thread: Air Conditioner up-date for a '73 911
    May 2012
    Chester, NJ
    Is there a firm that is offering a modern A/C system to replace the original systems...?
    Banned
    Nov 2004
    Scottsdale, AZ
    On SWB cars we start with a Behr evaporator assm, comp bracket, diffuser (under dash unit), rotary comp, Pro-Cooler, and 993 condenser/fan assm. Makes for an awesome system that allows the engine to run cooler because we jettison the engine lid condenser. The only significant violation of the body are the two holes for the evap box (inlet/outlet.)
    ’69-’73 cars are more of a challenge because of the left side battery box but a system can still be done with some creativity. Plan on spending $5k+ and be prepared for higher oil temps depending on your region.
    Sep 2006
    Maryland
    Frank, you use a 993 condenser/ fan, does that go in front of the driverside fender? I'd like to put one in my 71, the passenger battery box has been removed and a Carrera cooler mounted.
    Rob Abbott
    Banned
    Nov 2004
    Scottsdale, AZ
    The left front is where we mount the 993 cond/fan assm so you're looking at another boxectomy.
    It's a fairly cumbersome unit but the fan kicks butt which is THE KEY. Might even propel the car and qualify it as a hybrid.
    The original SWB systems used a left front condenser as well but they're not the most efficient things in the world.
    Sep 2006
    Maryland
    Thanks Frank, I think that may be the way to go.
    Sorry to hijack autofair. Try this: http://www.retroair.com/porscheairco...acfullkit.html
    Rob Abbott
    May 2012
    Chester, NJ
    Rob, Thanks for the link... I will give them a call tomorrow...Frank
    Sep 2006
    Maryland
    Do you have any pictures of the install? Particularly how low does the condenser protrude to the ground.
    Rob Abbott
    Nov 2011
    Reston, VA
    I've heard good things about Griffith's.
    http://www.griffiths.com/
    --Richard
    Early 911S Registry #2337
    Griffiths is probably the top quality of all, although I really think Franks 993 front condensor is a much better solution than Griffith's rear fender condenser. That's if you don't mind losing your battery box.
  1. FS: Factory BEHR air conditioner catalogue
    By gilbert911 in forum For Sale: 911 Parts
    Last Post: 02-09-2013, 11:48 AM
  2. 912 Air Conditioner compressor mount pic
    By doigthom in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 07-13-2012, 06:08 PM
  3. summer and your air conditioner
    By Reza in forum Off Topic
    Last Post: 05-30-2011, 09:25 AM
  4. Wanted- VPC air conditioner vents
    By redz350 in forum For Sale: 911 Parts
    Last Post: 08-17-2010, 09:23 AM
  5. CoA says Air-Conditioner
    By 911E&26R in forum General Info
    Last Post: 01-11-2010, 05:28 AM
