Thread: 73 S - correct horn set up??
    I would appreciate hearing what horn set up is correct for my 73 S. I have seen some cars with the dual long/short trumpet arrangement, and some with a single trumpet and round flat horn combo. I peaked inside the wheel well on Candyce's 73 Sepia 911S at the Parade, and it had a single horn accompanied by a round flat horn. Thank you!
    Depends when your car was made. There are many old threads discussing that topic on here use the search function
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Thank you and will do.
    Quote Originally Posted by BOYER73S View Post
    Aug 2011
    New York
    The first picture was early 1973, the second picture is late 1973.
    E Sully
    1973.5 911T
  1. Replies: 58
    Last Post: 11-03-2019, 05:12 PM
  2. Period correct horn button for Nardi Wheel
    By jaldeguer in forum General Info
    Last Post: 12-27-2013, 08:12 PM
  3. Correct horn set up 911E 1970
    By Nicklasliljegren in forum Technical Info
    Last Post: 07-22-2013, 05:13 PM
  4. Correct horn set up in a 1971
    By Rino71 in forum Technical Info
    Last Post: 11-09-2012, 07:12 PM
  5. Correct Light Weight Horn ????
    By TB73 in forum Technical Info
    Last Post: 01-31-2012, 05:39 PM
