Results 1 to 7 of 7
Thread: What are the options for original 73 MFI heat exchangers?
    Sep 2006
    San Francisco
    Right now I am running SSIs, although the left side does not have the third outlet for the snorkel pre-heater. My goal is to get as close to stock as possible.
    I figure there are 4 options:
    1. Get whatever Porsche is now offering (is it Dansk?)
    2. Dansk stainless steel (do they even offer a non-stainless?)
    3. SSI (may not be available, but it does appear they now offer the pre-heat on the left exchanger)
    4. Try to find an excellent used original set (like searching for a unicorn?)
    Any comments on the merits/issues with any of these options (or others) would be appreciated. I've never examined an original factory exchanger side-by-side with the other options, so don't know how close they are in appearance.
    Jeff Jensen
    I would stick with SSI's I don't think anyone would discount the use of SSI's, of course I'm not into the date matching stuff as others are. You might have a problem finding new SSI's as Dansk bought them and I don't know if production is running yet.
    Quote Originally Posted by mobius911 View Post
    . . . My goal is to get as close to stock as possible.
    4. Try to find an excellent used original set (like searching for a unicorn?) . . .
    That's what I did. Found everything I needed in about 3 weeks. I had help but . . . it can be done --- see post #384 . . .
    http://www.early911sregistry.org/for...ty-nine/page39
    People have been bad-mouthing/pulling-off originals for as long as these cars've been around. Not sure why. I replaced my OEM units --- after 43 years . . . so . . .
    5th option? . . .
    Find a Pipe Guy to fab-up that missing pre-heat fitting for your left-side HE --- how tough could it be?
    Prolly your cheapest option, as well
    HtH
    Feb 2011
    Northern VA
    I welded one in to my ssis. This is an easy job and w a little skill even looks factory.
    Sep 2006
    San Francisco
    Thanks for the ideas. The weld-on idea is a good one. I may try that route. I may then have them ceramic coated grey.
    Jeff
    Jeff Jensen
    Do you want to make your thermovalve functional again, or is this for esthetics only?
  1. WTB: MFI Heat Exchangers
    By hwgunner in forum For Sale: 911 Parts
    Last Post: 10-29-2013, 01:11 PM
  2. 914/6 heat exchangers
    By GCJeff in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 11-12-2012, 11:41 AM
  3. wtb - heat exchangers for 66' 911
    By vintage83 in forum For Sale: 911 Parts
    Last Post: 08-07-2008, 12:13 PM
  4. 74 heat exchangers on a 72
    By Dmill in forum Technical Info
    Last Post: 06-29-2007, 02:16 PM
  5. FS Original Heat exchangers 71T
    By WM711 in forum For Sale: 911 Parts
    Last Post: 04-28-2007, 09:45 AM
