Results 1 to 2 of 2
Thread: 1967 Rear Window Defogger
    Member JimVillers's Avatar
    Jul 2012
    Virginia Beach, VA
    I am trying to figure out the installation of the rear window defogger in my 1967 911. Do they face in or out? What held them in place? Were they feed air from the the socket in the side rail via that foam tubing or was there another type of tubing? Pictures would be wonderful (I could not find anything in the parts manual).
    Second question; what is the outlet tube on the driver's side heat exchanger for (on the neck of the heater box in the picture)?
    Jim Villers
    Virginia Beach, VA
    1961 190SL Mercedes, 1965 230SL Mercedes, 1965 356C Porsche, 1971 MGB, 1967 911 Chassis #305119
    The defroster tubes have a flange that slips onto the pinch weld seam, the tube is then held on by the installation of the window, the rubber seal hods the tube on the seam. I think I remember that they pretty much only go on one way. They were fed hot air by that now impossible to find orange tubing. We use a pretty decent replacement from Mc-Master Carr, however it IS NOT orange. That tube is for the heat hose to the thermostat on the MFI cars.
  1. Replies: 9
    Last Post: 08-24-2022, 03:21 AM
  2. FS: NOS # 901 613 045 00 switch heating defogger
    By 911 SWTARGA in forum For Sale: 911 Parts
    Last Post: 04-08-2014, 08:52 PM
  3. Replies: 1
    Last Post: 03-20-2014, 05:24 PM
  4. Rear window seal and rear shocks
    By Jazzman in forum Technical Info
    Last Post: 05-21-2011, 07:36 AM
