Thread: Rear control arm re-installation help needed
    Nov 2006
    S. F. Bay Area
    Spent most of afternoon trying to re-install the rear control arms (1967). Arms completely rebuilt with new elephant bushings. Other than a ginormous hammer, is there some trick to getting these things back into place? Thanks
    Brian
    S Reg #1032
    Yep, they're tough, you have to wriggle and push until you get the bushing into the mount far enough to see the bolt hole start to appear in the bracket hole, then insert pin punch or something similar and start levering the the rest of the way in using larger and larger levers until the bushing hole lines completely up with the mount hole until the bolt will tap through. Using a C-clamp to more fully compress the bushing will help get you started into the mount.
    Dallas, TX
    When I did this years ago, I bought 2 sets of extra long bolts. I ligned everything up and started screwing the first set of extra long bolts in, keep in the bushing cover level with the car. When the first set of bolts bottomed out, I went to a slightly shorter set and continued. When those bottomed out, I was able to then use the factory bolts.
    I am assuming the '67 mounts the same as a '73.
    Hope that helps.
    Neil
    Neil
    '73 911S targa
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    As Ed said earlier C clamp to get them started, when I fitted new bushes I think the arm was at least 5mm thicker.
    Tony
    Nov 2006
    S. F. Bay Area
    Thanks for the tips, guys, esp. the c-clamps. That did the trick. After about 15 years, the suspension is back on.
    Brian
    S Reg #1032
  1. Front Control Arm Bushing Installation?
    By jerryg in forum Technical Info
    Last Post: 03-23-2014, 06:25 PM
  2. OEM dead pedal installation advice needed
    By 66DC in forum Technical Info
    Last Post: 05-29-2013, 11:21 AM
  3. WTB: Mirror control switch needed
    By sabby in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 01-22-2013, 05:51 PM
  4. WTB: Mirror control switch needed
    By sabby in forum For Sale: 911 Parts
    Last Post: 01-21-2013, 08:13 PM
  5. radio installation and ID help needed
    By BOYER73S in forum Technical Info
    Last Post: 02-26-2011, 02:12 PM
