Results 1 to 10 of 15
Thread: 65 / 66 MY dash question
    Did all 65/66 911's come with a radio hole in the wooden dash, or was the dash delivered 'uncut' if a radio was not ordered?
    If they all had the holes, does that mean you got a radio delete plate if you didn't order a radio?
    Or did the delivering dealer cut the holes for the radio?
    Trying to work out how my new-to-me 65 was delivered.
    Cheers, Ryan
    Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
    Quote Originally Posted by obrut View Post
    Hi mate- pretty sure they were all prepped for radio; i had a Heuer Timemaster twin set in there when in my custodianship.......
    '65 901 SA '119' - 1st RHD Customer Delivered 911 Worldwide; 5710 Stone Grey/Green Leatherette 3 owners from new.
    '75 (Nov) 924 Group 4 Rallye. 9th o/all, 1st in class ‘79 Repco Round Australia Rally Barth/Kussmaul; 1st RHD chassis, 1st front engined Porsche to win an FIA event
    ‘78 928 Manual - early RHD Opalmetallic (gold) + Pasha
    '98 986
    ‘99 996 GT3 CS M003 ex Peter Fitzgerald. Falken livery. 2nd 2000, 3rd in 2001 Aus Nations Cup Championsip. Last of the road registered racers
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    i`v never seen an uncut fascia...
    a delete plate like this
    http://www.early911sregistry.org/for...nting-hardware
    was used on swb cars.
    franz
    Sep 2006
    La Quinta
    Yep, my guess would be all wood had the hole pre-cut with the delete plate or a radio.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Thanks Gents, most helpful as always.
    Cheers, Ryan
    Ok, I have two more 66 MY questions whilst I have a few experts on the hook:
    1. Should the shroud/collar part behind the rear seat pads be carpet or vinyl? I've seen both??
    2. Should the rear seat backs have a strap with a press stud fastener to hold them in the upright position?
    Cheers, Ryan
    Yup x 2.
    1. vinyl; there's a U shaped section from the bum-cushion (tech-term) about a palm's width (2nd tech-term) in height
    2. yes; black leather flap on outer edge of seat back with press stud on the rear parcel shelf lip.
    Don't have a pic of mine so here's an image from a UK RHD car c.200 from your VIN.
    Both correct for your car, Ryanski.
    '98 986
    Cheers again. Car is currently moving between various specialists to right a few wrongs, plus I have gathered from far and wide a small pile of correct parts to go in. Expect a set of photos shortly.
    Cheers, Ryan
    Another question - the under bonnet carpet needs to be replaced. The centre section is attached with two leather straps. What about the two side section - are they glued in?
    Cheers, Ryan
    Side sections were originally glued in
    John Schiavone
    Connecticut
  1. Dash Trim Question
    By Djthom in forum Technical Info
    Last Post: 10-23-2013, 11:47 AM
  2. lower dash resto question for 71S
    By Kaleid in forum Technical Info
    Last Post: 02-28-2011, 08:27 AM
  3. SWB Dash Question
    By TEE in forum General Info
    Last Post: 11-10-2010, 04:10 AM
  4. RHD - LHD Dash pad question
    By CamBiscuit in forum Technical Info
    Last Post: 02-25-2009, 02:04 PM
  5. early dash question
    By dmcummins in forum Technical Info
    Last Post: 06-15-2004, 05:48 PM
