Thread: TTG fog lights, is there a hole that needs to be tapped?
    Senior Member maspirito's Avatar
    Jan 2013
    lexington,kentucky
    I'm going to mount some TTG fogs and was wondering how the bracket
    Attaches to the body?
    Apr 2004
    35,000 ft
    You should find two plugged holes in each of your battery boxes. The brackets for the TTG lights should be tapped, so the bolts go thru the battery boxes into the brackets.
    Apr 2004
    35,000 ft
    I found some photos that should help
    Senior Member Merv's Avatar
    Jan 2013
    Queensland, Australia
    And if you have an early SWB that does not have battery boxes, this can easily be fabricated.
    Merv
    Member # 2633
    Cars:
    Porsche '68 - 911N (Sold)
    Porsche 356B (T-6) S Coupe
    Porsche 2010 Gen.2 Boxster S
    Jan 2013
    lexington,kentucky
    Thanks really helpful would not have figured that out
  1. Cutoff from 4 hole to 2 hole fender?
    By Christian Guthrie in forum General Info
    Last Post: 10-09-2011, 01:50 AM
  2. Hole in fender, what to do??
    By joeblow in forum Technical Info
    Last Post: 08-26-2010, 09:13 PM
  3. Hole-In-One Prize
    Last Post: 05-15-2006, 06:12 AM
  4. RSR roof hole?
    By rick2 in forum Technical Info
    Last Post: 02-09-2005, 08:23 AM
  5. RSR roof hole?
    By rick2 in forum General Info
    Last Post: 02-09-2005, 04:16 AM
