Results 1 to 10 of 10
Thread: Need help with 28 Row external oil cooler tab
    Apr 2011
    N.Calif., south of SF
    I was fortunate to have just found a 28 row external oil cooler. The top single mounting tab is missing. Does anyone have a picture and/or dimensions of one that would help me in the creation and location of a new one?
    Thanks.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Tab
    Here is one I have...
    Apr 2011
    Thanks Cliff. Very helpful. It seems it is angled off the face of the housing, but at 90 degrees +/- from the hose fittings?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Mar 2006
    8903one
    oil cooler-28 row
    Let me get a couple more pictures.It does have some details that need viewing...cliff
    Apr 2011
    Thank you Cliff. Very helpful. I had no idea the tab is what appears to be two pieces. Any measurements would also be great.
    Jeff
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    You'll need similar rubber cushions at the bottom too. Do you have the headlight bucket bracket?
    Apr 2011
    David- Thanks for this. I don't have the third rubber cushion but I'm lead to believe they are readily available. The bracket on the headlight .... good one. I don't know, I will have to look and see. Do you have any photos of this bracket.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    I'll see if I can get under my car to take a picture. I'm pretty sure mine is custom and screwed onto the headlamp bucket. The 73 cars did not have the welded in bracket as on later cars. It should just be a tab that the top mount screw goes through. You'll actually need 2 rubber cushions at the base.
    You might want to take a look at this thread, it looks like Elephant has a mounting kit.
    http://forums.pelicanparts.com/porsc...ay-garage.html
    Apr 2011
    Thanks David. I will check that out. Nice overview and detail of parts required.
    Jeff
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  1. 911 S without external oil cooler/lines ?????
    By J.Puppi in forum Technical Info
    Last Post: 05-14-2015, 10:12 AM
  2. Cleaning external cooler hard lines ...
    By Haasman in forum Technical Info
    Last Post: 06-18-2013, 09:40 PM
  3. FS: External Oil Cooler Mounting Hardware
    Last Post: 08-14-2005, 03:35 PM
  4. Replies: 18
    Last Post: 07-14-2005, 07:32 AM
  5. DIY install of external oil cooler questions...
    By bob tilton in forum General Info
    Last Post: 06-02-2005, 09:20 PM
