Results 1 to 2 of 2
Thread: bitumen fuel tank pad spare wheel pan
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    the spare part catalouge shows a part that is no longer available.
    it is a kind of self adhesive bitumen mat (i assume)sticked to the spare wheel pan in order to prevent noise or wear.
    my question is if this pad was put on the tank after mounting the tank in the car or was that done before.
    if it was done before that would mean that you have to cut it otherwise it would stick out a bit.
    i took a pic of this area of a 67 912 showing what i consider a debris of the part in question.
    i have several swb fuel tanks here but none has this pad.
    i dont have an uncoated fuel tank as it was used on very early cars--so maybe the part was just used on the uncoated ones..i doubt cause the 67 912 i took the pic had a coated tank.
    on some tanks it appears as if the pad was put on before coating.
    anyone any idea?
    May 2013
    AUSTRIA (tu felix)
    jep know where to get that stuff...thanks...but does not answer my question.
    franz
  1. Need new fuel tank: whats the biggest with full-size spare?
    By Veronica87911 in forum Technical Info
    Last Post: 03-17-2014, 01:54 PM
  2. FS: SC oem fuel tank and early 65 fuel tank
    By EARLY911ZOO in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 11-17-2013, 05:27 AM
  3. Spare Tire with 100L Tank
    By jaudette3 in forum Technical Info
    Last Post: 05-21-2013, 05:10 AM
  4. Replies: 5
    Last Post: 03-15-2011, 06:44 AM
  5. 85L tank + compressor + collapsable spare
    By thback in forum Technical Info
    Last Post: 09-25-2001, 08:00 AM
Tags for this Thread
