please make offers!
Regards Frank
please make offers!
Regards Frank
Porsche 911 S 1971 Kremer race car
FYI - There's a posting by 911 SWTARGA made on July 14th. for the sale of a pair of 4 hole horn grills.
Frank, I pm'd you yesterday...
Member #1616
I got a nice pair of 4 hole grills available
Richard aka le Zookeeper
early reg #1128
I have a good pair for $500. - Matt
Check out Unobtanium-Inc.com
New blog posts all the time!
have both 4screw grill Versions(there are 2 Versions of them dtey differ by with and hight)
have also the correct 65 engine lid.
located in austria
franz
I have these one, pm me if interested.
And me too! Best wishes, Robert
http://www.robertbarrielimited.com/parts.php
What is different about the first gen 64/65 decklids? I.E what is different from the other SWB decklids. Thanks
1965 911 Factory Paint to Sample Orange
1967 911S Bahama Yellow
1968 911 S Blood Orange
1971 911S Gold Metallic Peter Gregg
1974 Carrera RS Blue Metallic
1990 RUF RCT Estonia's car
there are several different lid Versions on swb cars
early cars did not have the 911 Designation only the Porsche lettering.
and on the inside of the frame there was a ledge welded on to hold a rubber seal.
also the stamping was a bit different.
the first 911 script was mounted slantwise on the lower right side --
later they changed Position to the center just below the grill...at the same time the Porsche lettering got wider and in single letters.
therefore the hole pattern is different...i even have seen different hole pattern on the slanted 911 script.
also different grill versions are known...some say the 64 did have different bars..i have not seen that so far.
what i have seen myself is different surface finish.
and on the early grills they used stainless stell nuts and steel washers on the threaded aluminum rods that hold the grill together.
i assume they canged this to aluminum nuts and washers to avoid galvanic corrosion.
did i forget anything?
