Results 1 to 9 of 9
Thread: Question: original looking rubber brake hoses for a '67
    Nov 2006
    S. F. Bay Area
    Received brake hoses from a reputable vendor. Fronts marked "OEM", have a white stripe, and dark-steel fittings. Rears say "aftermarket", have no stripe and yellow zinc fittings. Which, if either, is correct (as original)? (Sept '66 build '67)
    Brian
    S Reg #1032
    Nov 2006
    S. F. Bay Area
    Pretty please?
    Brian
    S Reg #1032
    Does it actually say OEM and aftermarket on the hoses?? Original hoses as I remember them have no writing or stripes on the hose, and yellow colored end fittings, I think this dates back to the 356 hoses.
    Senior Member jim amato's Avatar
    Feb 2011
    n.e. ohio
    here are some pics of brake hose removed from a 67 911, ate is marked on outer hose,Name:  original  brake hoses #1.jpg
Size:  37.1 KBName:  original brake hose #2.jpg
    registry #2072
    Nov 2006
    S. F. Bay Area
    No, the packaging was marked "OEM" and "aftermarket". I cleaned up an old hose and found "Ate" embossed on the rubber hose (as above), but no stripe, and what appear to be yellow-plated ends. I'll settle for new ones that look close to that. Thanks, guys, for the reply, and for the photo.
    Brian
    S Reg #1032
    You probably have to find NOS hoses, I think the current Ate hoses are different from originals.
    Nov 2006
    S. F. Bay Area
    Yes, they are a bit different. I really don't want to trust even new, old rubber hoses on a driven car. Since I'm not going concourse, I'm thinking of something close in appearance will do me. Thanks again.
    Brian
    S Reg #1032
    As a concour judge I can tell you that I personally would not count off for an updated brake hose, that is a safety item, as are seat belts, we judges are not supposed to 'see' that. So go ahead and show it
    Nov 2006
    S. F. Bay Area
    Cool. Thanks Ed, maybe I'll see you "on the lawn."
    Brian
    S Reg #1032
  1. Replies: 6
    Last Post: 12-21-2013, 01:06 PM
  2. Question re: assembling new brake lines/hoses ?
    Last Post: 07-10-2013, 02:17 PM
  3. FS: Front Brake Line Hoses and Hard Lines.
    By 76911S in forum For Sale: 911 Parts
    Last Post: 01-08-2013, 06:34 AM
  4. Length of brake hoses
    By RSTarga in forum Technical Info
    Last Post: 03-07-2012, 05:05 PM
  5. Source for original E-Brake rubber boot?
    By EsGeht in forum General Info
    Last Post: 05-11-2007, 04:41 AM
