Thread: Oil Hose-Case to Oil Tank Install
    Dec 2008
    Woodland Hills, CA
    Can you install the oil hose from the oil tank to the case with the heat exchanger in place? More specifically the fitting on the case (Drivers side long hose)? Or do I have to remove the heat exchanger to gain access? I've got the fitting started and is hand tight at this point. Any pointers or hints would be appreciated...
    Been there done that. Here's a Pelican Thread I started, with the consensus that you've got to take the heat exchanger back off.
    http://forums.pelicanparts.com/porsc...on-puzzle.html
    Mike
    Mike Caterino
    1970 T targa
    Santa Barbara, CA
    restoration blog: mk911.blogspot.com
    Dec 2008
    Woodland Hills, CA
    Exactly where I am at as well. Engine is on the floor ready to install. Like you I'm thinking about dealing with it once the motor is in the car...Grrr...
  1. 100 Liter Fuel Tank Install
    By gsjohnson in forum Technical Info
    Last Post: 11-12-2016, 05:48 AM
  2. 100 Liter Fuel Tank Install
    By gsjohnson in forum General Info
    Last Post: 03-07-2014, 05:57 PM
  3. Oil hose from case to oil tank?
    Last Post: 02-10-2013, 05:53 PM
  4. FS-NOS 65-71 engine to oil tank hose 911
    Last Post: 03-13-2011, 11:24 PM
  5. oil tank to cooler hose
    By John Fusco in forum Technical Info
    Last Post: 01-30-2011, 05:55 AM
