Thread: 901 Mounting Bolt
    901 Mounting Bolt
    Hello
    I had a front mounting bolt come loose and drop out along with the cupped washer and half of the aftermarket bushing. I reinstalled it with a new bolt and used an
    external tooth lock washer. The bolt is fine threaded and I could not get it to completely snug up. Rather than risk stripping it I left it. Has anyone had the same problem? Would you use a thread locker/sealant?
    Aug 2007
    Phila Pa. area
    901 mounting bolt of what?
    Mike
    You might consider running a tap into the threads to clean them up before totally ruining them by trying to tighten the bolt against known bad threads.
    Thanks Ed, will run a chaser through it.
    Quote Originally Posted by mike curnow View Post
    I am guessing transmission mount.
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    The bolt and cup washer are still available from Porsche.
    Tony
  1. 901 trans mounting bolt
    By 50/50 in forum Technical Info
    Last Post: 07-01-2013, 02:47 PM
  2. Replies: 0
    Last Post: 04-02-2013, 07:02 PM
  3. Rear shock mounting bolt
    By spankie in forum Technical Info
    Last Post: 06-25-2012, 03:58 PM
  4. Fan Shroud Clamp, 2 bolt vs. 1 bolt, 2.4 liter engines
    By caproader in forum Technical Info
    Last Post: 12-15-2010, 04:22 PM
  5. FS: Autopower Roll Cage - bolt in, bolt together
    By greggearhead in forum For Sale: 911 Parts
    Last Post: 06-17-2010, 01:01 PM
