Results 1 to 10 of 14
Thread: 68 S Technical Questions
    Port Macquarie, Australia
    Hi All
    I have a 68 S engine I'll be cleaning up, it currently has a black engine shroud... is this correct for the year or should it be red like LWB cars?
    Also need to know what the thread size and pitch is on the earth stud by the gearbox... definitely not 8x1.25mm like the front one by the battery
    John Forcier
    EarlyS #1987
    Restoration Saga
    red shroud for all S, SWB and lwb
    Quote Originally Posted by 66S View Post
    Thanks for that.
    John Forcier
    EarlyS #1987
    Restoration Saga
    The ground stud is supposed to be 8mm x 1.25, don't know what you have, but it has always been that size.
    Bizarre. I've tried all the nuts I have with no success. My callipers read 7mm, and the 8x1.25 die slips down the post. Not sure what to do other than chase a new M6 thread onto the stud. The joys of old cars
    John Forcier
    EarlyS #1987
    Restoration Saga
    I'll bet that stud has been reduced in size by that old devil rust, ie. eaten away to a smaller diameter. I'd weld a fresh bolt to a washer then weld (or braze) the washer to the bulkhead after removing the original. I think I'd want the larger size to ensure good tight grounding.
    old softie67S
    Feb 2007
    Sanibel Fl
    When shopping for a correct red shroud, remember there was no channel to the oil cooler on the early cars
    Tom
    67S soft rear window
    60 356 Cab
    70 914-6 3.2 short stroke twin plug
    05 Audi S4 Cabrio (commuter)
    05 Audi Alroad (family driver)
    Aprilia SR 50R (Sanibel scoot)
    I am putting an S shroud in my 68. I had a difficult time finding one so I had this one made.
    Name:  69S shroud series900.jpeg
    Dan
    MBR #2637
    AKA boschdog
    1968 911 Normal Coupe
    Houston, Texas
    Dec 2008
    Woodland Hills, CA
    So what did that set you back?
    Some sanding finds the red shroud underneath... I don't know why a PO painted it black? Not sure I'll be able to remove the black paint without damaging the original red. I have a later red shroud with the air channel to the cooler and will use it I think as the car will be used for historic racing. I think I need to source the cone that goes on the alternator as it doesn't have the fins riveted on the shroud like early versions.
    Another query... will turbo tie-rods fit up to a SWB front end? I'd prefer to use these over the early units, but the Pelican units are marked for 69>
    John Forcier
    EarlyS #1987
    Restoration Saga
  1. Best of...Technical Info
    By 72targa in forum Technical Info
    Last Post: 07-27-2021, 01:49 PM
  2. Technical Bulletin Help
    By Allen Henderson in forum General Info
    Last Post: 08-23-2012, 11:15 AM
  3. FS 356 Technical Manual
    By Bobby Smith in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 01-02-2012, 11:27 AM
  4. technical books
    By kllr901 in forum For Sale: 911 Parts
    Last Post: 09-11-2011, 07:25 AM
  5. Technical Specifications Set of 4
    Last Post: 05-12-2010, 12:39 PM
