http://cgi.ebay.com/ebaymotors/Porsc...orcev4exp=true
A few months ago I bought this Porsche 911 Targa 1972. Unfortunately, the car is very bad. Although the Classic Car seller from Saint Louis advertised that the Porsche was restored very beautiful. I would like to place an ad fair, therefore the full list of defects;
I have 62 photos of damage, and this is without the pictures of the engine. It is certainly not “beautifull restauration”. COA Porsche document is not in the car (is the car really matching number ??)
Whole car is full of filler. Rust holes are filled with thin layer of filler.
Rear Deck, can not be mounted, chassis inside is rotten from rust
Front Fender Left , rust holes on the inside filled with Teflon tape
Front Fender right, holes on the bottom side. Front Bumper is completely rust holes
Rear Panel, filler and fiber mats. Chassis left, inner sill outer sill, pieces welded.
Chassis right, painted on the rust over inner sill. Rusted doors on left and right on bottom. Hood completely rust full of filter
Chrome frames are glued on the chassis, and let loose. Door and window on driver are skewed
Almost all rubbers are loose or badly glued. The tires are torn and completely dried out.
On almost all rubbers sits paint. Driver's seat, the frame is broken. Wheelhouse rubber, left and right torn
Air condition is not working. Hazard is not working. Beam is not working. One window does not close
Gearbox oil leaks. Engine block is leaking a lot of oil (it trickles out)
Heat exchanger is sprayed with silver flammable paint. Oil level transmitter is unusable
All rubbers in the suspension are porous or rotten.Raised wheel HUB steerwheel is not in the car !
(The steering has exceeding play).Radio “Frankfurt” is not in the car !
Shock absorbers are worn. Head gaskets must be replacement. Wiper pump and watertank is missing
Next time i buy a car, I google ; " company name + complaints "
