Thread: MFI part number help
    I'm looking for a part number for this rubber block and a recommended supplier as well.
    Thanks!
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Paul are you ready for this?
    916 110 330 00
    Sierra and Pelican show them in stock, Stoddard doesn't but their database is usually weak, they probably do have it, call Maurice
    When was last time you saw a 916 part number!
    Paul, they are also readily available through your local friendly Porsche dealer, which may be where they all come from anyhow!
    Yup........
    -Marco
    TLG Auto: Website
    I knew it would be easy but I wasn't having much luck with the PET diagrams...not skilled enough for that.
    Thanks to all!
    Paul Abbott
    Early S Member #18
    530.520.5816
    In this case, the number applied to a fuel line support from the 6-cylinder, 4-cam 916 engine, a part later used on 911 MFI engines. The 916 number also applied to the 908 Spyder transmission and 914/6 GT-based road car.
    Jon B.
    Vista, CA
  1. Need help with part number
    Last Post: 11-06-2013, 10:14 PM
  2. Need help with part number
    By platas in forum General Info
    Last Post: 11-04-2013, 12:55 PM
  3. part number 901 107 696 40
    Last Post: 07-27-2010, 06:17 AM
  4. Help with part number 901.501.898.0
    By WM711 in forum General Info
    Last Post: 02-07-2007, 10:35 AM
  5. need help on another part number
    By MY911S in forum Technical Info
    Last Post: 02-21-2002, 06:03 PM
