Thread: New guy needing buying advice
    Greetings,
    Been lurking for a while-Love the site.
    After 997.2 and 3.2 Carrera ownership, in that order, I guess it only natural that I've now become quite obsessed with the early 911. Unfortunately, my budget limit is $30k. Not sure if that is realistic, but I've seen a few decent condition T's in that range. I tried searching but was wondering if there's a thread/sticky that explains the differences in the years, models, wheelbases, motors, and pros and cons of each. I don't need a show car-just something I can drive while fixing up. Actually prefer the more original cars w/ minor bumps & bruises.
    If my budget isn't realistic, maybe a 912 conversion an option? pros and cons to that?
    One last thing- I'm 6-4, torso long-Are sunroof cars tight on headroom? Older cars easy to lower seat brackets?
    TIA
    hi,
    I sold my 1960 356 cab about 2 years ago, joined the 911S registry and started looking for a 67-73 car. It took about a year but I found a car for under $30k that was both numbers matching and passed a PPI with great mechanicals and only some needed cosmetics. I chased a lot of cars, mainly by phone and with photos as i live in a rural area of Idaho. I had a PPI done on one car that was a rust bucket and not as presented so the major item to not avoid is a PPI by a competent shop even if you can see and drive the car. I was open to both coupe and targa, wanted best car I could find, and bought a 71 T targa. It was my 5th Porsche but my first 911. The Registry is a great resource and I have been using it as I sort out my car and make improvements. I am 6 ft 3 in and a 911 has scads of room for us tall guys. Good luck with your search.
    al kuresman
    Senior Member boba's Avatar
    Jul 2006
    DFW
    I am 6'3" and yes a sunroof does reduce headroom. Your build and how you sit will effect how much. Your selection of a seat and its mounting can gain back some of what the sunroof takes.
    I think you can find a driver within your budget. You should also think about ongoing maintenance budget. A "good deal" project car may bury you to get it to where it becomes what you wanted.
    912 to 911, backdates, and hot rods are all a 'value function' of how well they are done and attention to detail. There is also the question of how well the creators tastes match your own.
    The way I think about listing the cars:
    '64-'66 SWB, solid mount front struts
    '66-'68 SWB
    '69 LWB 2.0lt
    '70-'71 LWB 2.2lt
    '72-'73 LWB 2.4lt '72 had one year only oil door
    '73.5. LWB 2.4lt CIS
    There are of course additional sub groupings and special factory builds (911R) but that would take a book, or books.
    65 356SC Dolphin Gray
    66 912 Green
    69 911E Tangerine
    72 911T GP White
    72 911T Aubergine
    72 911T Lilac
    72 911S Black (voodoo)
    90 964C4 Black Targa
    94 964C2 Black Coupe
    08 GT3 Speed Yellow
    If you want a summary of each year and the changes Porsche made then buy James Schrager's book "Buying, Driving, and Enjoying the Porsche 911 and 912 - 1965-1973. Great book that also gives info on what to look for when buying a car.
    Luft gekuhlt Bummler's Avatar
    May 2005
    The Valley...
    Quote Originally Posted by laneranch View Post
    Pete Zimmermans book as well is a great resource for those looking for a year by year review of changes and particular issues with model years. It may be out of print...
    http://www.amazon.com/Used-911-Story...Pete+Zimmerman
    Stefan Josef Koch
    RGruppe #194/SRegistry #1063
    2015 Porsche Cayman S
    Great read and cool info on little subtle differences. Thanks!
  1. Value of 1966 911 needing restoration
    By ghost1001 in forum General Info
    Last Post: 06-27-2012, 11:16 AM
  2. Better than a non running, non S, needing restoration SWT for 75K!!
    By Rennman in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 04-04-2012, 07:17 AM
  3. Advice on buying this SC
    By Intheshop in forum General Info
    Last Post: 08-29-2007, 01:26 PM
  4. Value of '67S needing restoration.
    By rngpc in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 05-03-2006, 06:40 PM
  5. some advice re:buying used 2.4
    By joelrkaplan in forum Technical Info
    Last Post: 01-27-2004, 03:13 PM
