Thread: Rebuilding steering box, and???
    Nov 2006
    S. F. Bay Area
    ..how does one remove the rubber/metal bushings on the ends of the rack. I can't get the large nut to budge. Is the end threaded on? Threaded IN? (for a 1967) Thanks
    Brian
    S Reg #1032
    Restoration newbie.
    Jun 2007
    San Francisco
    Does this help?
    Name:  Screen Shot 2013-07-31 at 11.56.26 AM.jpg
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Nov 2006
    S. F. Bay Area
    Helps immensely! Thanks for taking the time to put that up. Brian
    Brian
    S Reg #1032
    SWB Steering Rack Adjustments
    Original "Silentbloc" eyebolts must be installed at precise angles, dimensions "to ensure free movement of the steering components and exact guiding of the tie rods". Such adjustments are not necessary if using later Turbo-style tie rods.
    Factory tools, below, for rebuilding SWB steering racks with Silentbloc eyebolts. Large fixture P285 was provided with correct 8.5 degree angle, dimensions for proper re-assembly. It's also convenient for holding rack when undoing or re-torquing eyebolt nuts.
    Jon B.
    Vista, CA
    Adjustment Values
    For future reference, here are legible adjustment values for SWB steering gear eyebolts, from manual page posted above...
    Jon B.
    Vista, CA
    May 2011
    Chelsea, Québec
    Now that's just too cool...
    Quote Originally Posted by Jon B View Post
    Jon B.
    Vista, CA
    Member #1616
  1. Rebuilding a 69 ignition switch
    By EA911 in forum Technical Info
    Last Post: 05-10-2013, 06:37 PM
  2. Rebuilding 68 911 S Dashboard
    Last Post: 04-26-2012, 05:26 PM
  3. Rebuilding Seats
    By daepp in forum General Info
    Last Post: 01-02-2007, 01:18 PM
  4. Rebuilding CD Box
    By rick2 in forum Technical Info
    Last Post: 05-17-2005, 05:46 PM
  5. rebuilding sport seat
    By dpegan in forum Technical Info
    Last Post: 03-25-2004, 05:28 AM
