Thread: Different approach to securing loose jack in front trunk
    I've found a cost effective solution to securing your loose jack in the front boot.
    Mine has been banging around in there for the past few months....or worse, sitting in the garage.
    I found these on the internet/ebay.
    They are called Quick Fist rubber clamps.
    Used a lot on jeeps, etc for securing shovels and other implements of destruction onto the vehicle.
    Looked like it might work for the Pcar as well.
    They are not expensive and come in varying sizes.
    It did require drilling a couple of holes in the front bulkhead (behind the bumper), but my car is just a hotrod so that wasn't any issue.
    They are a snap to install and are rated at 25 lbs capacity each (50 lbs total), so have no trouble holding onto my Bilstein jack.
    Installation almost looks "factory" and is so easy to remove/secure the jack.
    Now I'll always have my jack with me.
    I think this would be a great way to go for any hotrod, R Gruppe-r, etc.
    Here are the pics:
    -Doug
    2022 Carrera 4S Oslo Blue
    1977 Martini Edition 924
    1989 Lancia Delta Integrale 16V
    Senior Member CidTito's Avatar
    Jan 2008
    Emeryville, California
    a very classy solution. I really like it. To fasten the Quick Fist, how did you do it?
    E911SR #2107
    69 911T/S SWT 3.2L
    RG #384
    Quote Originally Posted by CidTito View Post
    One small bolt thru each with a nut on the backside (behind the bumper) does it...
    -Doug
  1. Securing Grill Badge?
    By Irish911 in forum General Info
    Last Post: 03-26-2013, 09:26 AM
  2. Proper jack placement in trunk
    By 356robo in forum General Info
    Last Post: 11-13-2009, 01:19 PM
  3. Front jack point?
    Last Post: 04-28-2007, 01:04 AM
  4. Front trunk paint?
    By tom dance in forum Technical Info
    Last Post: 08-20-2005, 05:03 AM
