Results 1 to 9 of 9
Thread: Engine number help!
    Engine number help!
    Hi, I was wondering if anyone on the forum can help me research an engine number to see if it lines up with the year/model, "6290595"
    Much appreciated!
    '79 case 930/04 SC case.
    Early S Registry #235
    rgruppe #111
    Quote Originally Posted by sithot View Post
    Ack! Is something screwy going on here? Should be for an 'E'
    Quote Originally Posted by schnell View Post
    Hi, I was wondering if anyone on the forum can help me research an engine number to see if it lines up with the year/model, "6290595" Much appreciated!
    Here you go...
    Jon B.
    Vista, CA
    Engine Typ number
    901/09 = 1969 911e mfi
    Ernie W
    member of Early 911S Registry
    thanks all, that's a relief!
    Aug 2009
    SF Bay Area
    It is a 69 911E. probably made about 1/3 of the way through the 69 model run
    Jim
    Good news.
    This site lists an "8" after the 629. The 629XXXX is a '79 SC number.
    http://www.frwilk.com/the944/eng_data.htm
    Bad information and no books. Don't believe everything you read on the internet.
    Tom
    rgruppe #111
    Oct 2008
    Burford, ON, Canada
    The engine serial should always be accompanied by the engine type #. There are many cases where the factory used the same serial series, but with a different type #.
  1. No engine number??
    By ccporsche in forum Other Porsche Passions
    Last Post: 06-03-2013, 06:26 AM
  2. Need help with engine number
    By 74USCarrera in forum Technical Info
    Last Post: 05-06-2013, 07:13 AM
  3. 2.4S Engine number
    By CHK in forum Technical Info
    Last Post: 12-09-2007, 01:17 PM
  4. Engine Number
    By mwilson3003 in forum Technical Info
    Last Post: 08-03-2007, 01:29 PM
  5. Engine Number help
    By Vintage911racer in forum Technical Info
    Last Post: 11-15-2003, 07:39 AM
