Thread: The Canary: Air cleaner hose's
    Jun 2013
    Mill Valley, CA
    1969 911 2.0L
    First newbie engine question. So I pulled off the air cleaner assembly from the top of the carbs because... I can... and I have a big hose and a small hose, the big hose is the oil return but where does the small hose attach to? It has no clamp on the other end? I feel so ashamed....
    Cheers
    -Kav
Size:  87.8 KBName:  911_engine.2.jpg
    The small hose is a drain line for anything like oil, water, gas that may settle in the bottom of the air cleaner. There is an attachment point.
    Early S Registry #235
    rgruppe #111
    if you look beyond where you put an arrow for the small hose, you will see/or not, a small metal tube protruding thru the rear sheet metal. It goes to a collector with a rubber boot down the other end to catch excess oil vapors. you cannot see the other end as it drops down next to the flywheel.
    in the foto you can see, it is the small tube hanging just left of the flywheel that drops down with a rubber end (actually the rubber boot is missing in this foto)that has a slit to let oil vapors accumulated to exit south.
    the tube has a smaller angled end that points towards the air box where that small hose attaches to,.
    Richard aka le Zookeeper
    early reg #1128
    Jun 2013
    Mill Valley, CA
    Thanks all!
    -Kav
  1. The Canary: Brake rotor replacement
    By kav in forum Technical Info
    Last Post: 09-21-2013, 05:42 PM
  2. FS: @Road Scholars - Canary Yellow 67S SWT
    By vipergruen in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-11-2013, 09:28 PM
  3. The Canary: Engine upgrade 2.0 to 2.2
    Last Post: 09-04-2013, 11:07 AM
  4. Hose's incl Orange Hose
    Last Post: 12-10-2009, 03:19 PM
  5. Canary Yellow
    Last Post: 02-01-2006, 01:46 PM
