Thread: Car maintenance / history software?
    Jun 2013
    Mill Valley, CA
    Luckily my car came with a large amount of maintenance receipts and I'm looking for a piece of software where I can input all of these records to build a maintenance database, anybody use something like that?
    Cheers
    -Kav
    Senior Member setho's Avatar
    Dec 2012
    New York
    I'm not using a dedicated program for the purpose, but using Evernote.
    It's cross platform, easily takes in different types of files, and with an add on, clips from the web.
    It syncs to the cloud, and has good search capabilities.
    Check it out at:
    http://www.evernote.com
    Seth O.
    ESR #2474
    1966 911 - '77 2.7L Hot Rod
    1967 Pontiac Bonneville - '70 455
    2000 996
    WANTED: 1966 Transaxle 229835-902/1
    Jun 2013
    Mill Valley, CA
    Cool, I'll check it out.
    Cheers
    -Kav
    Jan 2012
    Green Mountains
    I've just used a simple spreadsheet. Adding scanned receipts adds a level of complexity, particularly if you want to index or search against the contents of the documents. Depending on your willingness to experiment with software, it's certainly something that can be done.
    I recently purchased an iPhone app called Scanner Pro based on the recommendation of a colleague whose judgement I trust. http://readdle.com/products/scannerpro/ I haven't used it yet, but if my bank will accept an iPhone photo of a check, there's no reason this wouldn't work to produce useful scans quickly.
    The photo > PDF > searchable text workflow may be a bit more complicated, but all the pieces exist to do it well. Interesting problem. I'm going to experiment a bit while I'm on vacation...
    Terrence Dorsey
  1. Value/Addtional History: 1970 911 Coupe w History?
    By mrbmw2002 in forum General Info
    Last Post: 06-26-2022, 11:55 AM
  2. Car maintenance / history software?
    By kav in forum General Info
    Last Post: 08-05-2013, 04:20 AM
  3. Maintenance Record **NOS**
    By dinogoetz in forum For Sale: 911 Parts
    Last Post: 02-24-2010, 02:24 PM
  4. Request for new photo software..please
    By dhopkins in forum General Info
    Last Post: 03-03-2006, 07:47 AM
