Thread: Joining panel putty
    Senior Member 911kiwi's Avatar
    Feb 2003
    Auckland, New Zealand. And Los Angeles, USA.
    Joining panel putty
    Hi Guys,
    I'm about to re-attach/rebolt the front fenders on my '67SWB after minor rust repair. When removing them I noticed a grey putty strip that adhered to the joining surfaces of the fender and chassis. Is this available still? A Wurth product perhaps? It appeared to be in a strip form and after 46 years was still relatively soft.
    What are the restoration guys amongst you using as a replacement?
    Cheers
    Gary
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Early S Registry # 306
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    http://eshop.wuerth.de/Dichtungsband...R/?CategoryID=
    You'll probably have to search again in US würth store.
    Cheers
    Uli
    Feb 2003
    Danke, Uli. That's excatly what I was looking for!!! :-)
    Cheers
    Gary
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    It is a Henkel Product- Teroson Terostat - which is shown on the PET as Part Number 000.043.129.00
    It is available from an OPC against this Part Number in a 5m roll but is quite expensive.
    When it turns up it is now 20mm x 2mm thick.
    I have tried to buy it from Henkel in the UK but I can't find it in the correct size.
    3M make a Scotch -Seal Mastic Tape 5313 in 20mm x 2mm thick which works well and is supplied in 20metre rolls.
  1. Replies: 11
    Last Post: 01-31-2014, 01:13 PM
  2. FS: @356Registry - Fender Joining Panel & Rocker Panel Support
    By mshaver51 in forum For Sale: 911 Parts
    Last Post: 03-16-2013, 07:42 AM
  3. nos fender joining panels 911/912 65-
    By jim amato in forum For Sale: 911 Parts
    Last Post: 08-23-2012, 03:53 AM
  4. Nice early '70s bag, black basketweave, putty interior...
    By nesslar in forum For Sale: 911 Parts
    Last Post: 03-03-2012, 05:58 PM
  5. Thanks for joining the 356's on Saturday and...
    By Jeff Trask in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 05-10-2007, 01:05 PM
