Thread: Simple Alternator Connection Question
    Aug 2005
    VA
    I thought I had labeled all wire upon disassembly but apparently missed a couple.
    Just to avoid any additional mishaps, and I have had a few, with my rebuild / assembly, can some please confirm on which terminal the big red wire connects to on my alternator. I searched but did not find.
    Chris
    73 911 E
    Feb 2012
    Edmonton
    Red wire should go to "B+"
    Blue wire should go to "D+" or "61"
    Brown wire should go to "D-"
    Black wire should go to "DF"
    Aug 2005
    VA
    I have:
    Red wire
    black and brown plug
    Green small wire
    ground strap
    Red goes to B
    Green goes to A because that is the only place it fits
    Black and brown are plugs so they plug in
    That leaves the ground strap Where does that go?
    The ground strap goes to the stud in the 4:00 position, after you install the cone it will go under the nut.
    Aug 2005
    VA
    Perfect!
    Thanks!
    Chris
    73 911 E
  1. another alternator question
    By vtrich in forum Technical Info
    Last Post: 08-16-2018, 05:52 PM
  2. horn wire connection question
    By angustami in forum Technical Info
    Last Post: 12-20-2012, 07:40 AM
  3. Simple 73 (or poss 72) seat belt question.
    By Haasman in forum Technical Info
    Last Post: 12-05-2012, 07:48 PM
  4. simple wiring question for TTG...
    By Kaleid in forum Technical Info
    Last Post: 05-13-2008, 07:56 PM
  5. Simple paint question - Glasurit
    By Justin in forum General Info
    Last Post: 02-01-2005, 10:16 PM
