Results 1 to 2 of 2
Thread: Evaporative hose connector question...
    Jun 2012
    Northern Ca
    I have a '73 with a non-stock 'newer' swirlpot gas tank and want to keep most of the evaporative system but the tank (top) outlet accommodates an ~9mm ID hose and the first spliter needs an ~15mm ID hose. Are there some "fuel safe" plastic connectors or metal connector/union/enlarger that will help with the transition to a larger hose?
    thanks,
    Name:  Hose transitions.jpg
    kj
    73 E Targa
    Jun 2012
    Northern Ca
    ... found some Nylon "reducing coupling" for 5/8" to 3/8" which should work. I'm surprised none of the charts or illustrations show it graphically. Maybe my different gas tank config. doesn't match the older evap. system I have?
    kj
    73 E Targa
  1. Replies: 0
    Last Post: 05-13-2013, 02:48 PM
  2. Fuel evaporative system up front
    By speedo in forum Technical Info
    Last Post: 03-20-2013, 04:42 PM
  3. Rubber wiring connector question
    By Max (SD) in forum General Info
    Last Post: 10-17-2010, 03:45 PM
  4. 72E Oil hose question
    By A_Alfa in forum Technical Info
    Last Post: 12-11-2007, 05:37 PM
