Results 1 to 8 of 8
Thread: Shroud Identification and Assistance
    Hi All
    The engine shround that came on my "69E is obviously not the correct one, but will have to suffice until I source the proper one. Can I get some help identifying which shroud I have as well as the following questions:
    1) Should it have some type of internal air deflection componentry?
    2) Why is the fit so bad to the oil cooler shoud? I'm assuming both of these parts were sourced independently from different cars.
    If anyone knows the wherabouts of a '69 E shroud....
    Darren
    Name:  Engine Shroud To Cooler.jpg
Size:  124.7 KBName:  Engine Shroud Front.jpg
Size:  128.0 KBName:  Engine Shroud Top.jpg
    Loos like a modified SC/Turbo shroud with a hacked off early, long, grey air shroud for the oil cooler.
    The fan shroud and air tin inside it are OK - someone just opened up the injector holes. The alternator air guide meets up with the tin that's riveted to the shroud to duct the air to the cooler. The great piece is a cut-off from an earlier shroud. The right piece is readily available.
    -Marco
    TLG Auto: Website
    May 2006
    CT
    This should help.
    I may have the one you need.
    PM me to follow-up
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Thanks guys, appreciate the help. Tom, sending PM
    Quote Originally Posted by tom1394racing View Post
    This should help.
    PM me to follow-up
    Tom, don't forget that he needs the gray, plastic air guide for the cooler.
    -Marco
    TLG Auto: Website
    May 2006
    CT
    The 2.0 engines did not use either the grey alternator airflow guide or the grey oil cooler flow guide. The 2.0 engines used an airflow guide riveted to the inside of the shroud and a small sheet metal piece to guide air over the cooler. See the attached diagram from the PET
    Tom Butler
    1973 RSR Clone
    1970 911E
    That's right. I forgot he was looking for the 69E shroud. I thought he was going to re-use the red one he currently has... ops:
    -Marco
    TLG Auto: Website
    The air guide is two pieces of fiberglass with a flat metal plate riveted to them.
    The entire assembly uses 3 rivets on each side to attach it to the shroud.
    The new cooling assembly shows up on the 2.2 cars and was riveted to the shroud. Here is one that Damon Josz (Series 900) made.
    Tom
    PS: Tom is a good bet for an original. They aren't easy to find in good condition. Most are cracked, beat up and plain worn out by now.
    Early S Registry #235
    rgruppe #111
  1. Need information / help / assistance on a car
    By DAVSER in forum Other Porsche Passions
    Last Post: 05-30-2013, 08:24 AM
  2. Possible Assistance in Houston?
    By SWBS in forum Texas
    Last Post: 02-09-2012, 06:05 PM
  3. Need Some Assistance in New Hampshire
    By ennisk1 in forum Technical Info
    Last Post: 07-01-2009, 06:01 AM
  4. Oil Pump Assistance
    By CamBiscuit in forum Technical Info
    Last Post: 02-20-2008, 07:02 AM
  5. Travel assistance list
    By preS in forum General Info
    Last Post: 09-14-2005, 07:35 AM
