Results 1 to 8 of 8
Thread: How to remove dash pad on 73
    Or should I leave it in place? Annie is going to paint this week. Trim is stripped and engine dropped. The dash pad only has one small crack and otherwise is perfect. AM I tempting fate by considering pulling the pad for protection. I've read that its easy to hurt one by pulling it. I've searched, but haven't found a diy. thx
    1973 S Targa #0098
    Member # 1498
    There are around 5 or 6 horizontal studs with M6 nuts accessed through the heater/ventilation components, one vertical stud accessed through the speedo hole. Pull the lower edge of the dash towards you to release the horizontal studs, then pull up vertically. There are also 4 or so vertical pins pushed into plastic plugs, which should pop out.
    Dec 2008
    Woodland Hills, CA
    I'd consider a good replacement... I know they're expensive, but all that effort and expense to paint and restore...and you're going to skimp on the dash? And now's the time. Just sayin'...
    Aug 2011
    New York
    I wouldn't consider using an original dash in good shape with one small crack skimping.Original in good shape is better in my opinion.
    E Sully
    1973.5 911T
    Dec 2008
    Woodland Hills, CA
    Maybe if we could see the crack a more definitive opinion could be given. Wouldn't you think that a small crack would become larger over time?
    Here's a pic. The rest of the dash is perfect. I decided to leave it in place after speaking with the painter. Thanks for the input.
    1973 S Targa #0098
    Member # 1498
    Dec 2008
    Woodland Hills, CA
    Yea that's not too bad. I see why you have elected to leave it. For sure don't remove it as I'm sure your painter is capable of protecting it..
    Atlanta, GA
    Quote Originally Posted by gsjohnson View Post
    Has anyone had any success repairing a small crack like this?
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
  1. How do you remove the cigarette lighter from the dash??
    By ruxtonisl in forum Technical Info
    Last Post: 03-05-2014, 05:57 PM
  2. How do I remove lens from H1?
    By Alan B in forum Technical Info
    Last Post: 10-03-2007, 08:57 AM
  3. How to remove A/C system?
    By berettafan in forum Technical Info
    Last Post: 11-09-2006, 10:09 AM
  4. How do you remove an SWB dash?
    By 304065 in forum Technical Info
    Last Post: 10-03-2006, 10:34 AM
  5. how to remove dash knee pad in a SWB?
    By bob tilton in forum General Info
    Last Post: 11-20-2004, 12:38 PM
