Thread: 72 oil door & good luck x2
    Jun 2011
    Bellingham, WA
    Opened my oil door to add a qt and noticed that the rod which releases the door was loose & flopping around. I don't know how you would get the door open if the rod let loose with door closed.
    second bit of luck is that the plastic piece that holds the rod into the latch is still availible form Porsche as it is still used in many places. part number 993 531 563 00 (plastic trim). and its only 98 cents
    Check your plastic rod holder
    Tom
    Nov 2011
    US
    Would this also be the same piece as on the rear deck lid release? Can you post a picture of the one you mean.
    For 98 cents I might buy a couple just to verify there is a P car part less than a dollar! ;-)
    Jun 2011
    Mound, Louisiana
    Thanks! Will do!
    Paul Harrop 12.5% German.
    Early S #2059
  1. Luck repairing cracked taillight lens?
    By merbesfield in forum Technical Info
    Last Post: 01-06-2014, 07:23 AM
  2. Are these door pockets any good?
    By frankmar in forum General Info
    Last Post: 02-13-2013, 09:21 AM
  3. Good original SWB Door Tops
    Last Post: 07-12-2012, 10:14 PM
  4. No Luck in posting photos!
    By Redfish1 in forum Test Area/Help
    Last Post: 05-01-2007, 07:51 AM
  5. No Luck in posting photos!
    By Redfish1 in forum Membership Questions
    Last Post: 04-30-2007, 03:42 PM
