Thread: shift light ?
    Aug 2012
    France
    shift light ?
    I am running a 3,2 1984 engine with motronic but with PMO carbs - meaning no rev limiter anymore. I'd l'ike to install a shift light, as am doing many trackdays. Any recommandations on a model and installation ?
    Thanks Xavier.
    O-G 26 - Early911S 2407
    Aug 2011
    New York
    Are you still using the Motronic for the ignition? If so, you may want to contact Steve Wong and see if he can program a chip using the existing shift light system. Maybe see about using a rev limiting rotor in the distributor. I don't know if he has done any chip tuning for carburetors, but never hurts to ask.
    http://www.911chips.com/
    E Sully
    1973.5 911T
    Aug 2012
    France
    Thanks E, I will do
    There are as many as a dog has fleas. Many get mounted in the clock space. Most of these are dash mounted.
    http://www.jegs.com/webapp/wcs/store...erm=shift+ligt
    Good luck.
    Early S Registry #235
    rgruppe #111
    Aug 2012
    France
    Quote Originally Posted by sithot View Post
    Good luck.
    greetings, are you using any one of these ? I am more interested about the sertup as I am still running the Motronic for the Ignition only.
    Raptor makes a nice one. Installation is easy. Purple/Violet & Black wire (tach signal) and a ground. Put it wherever you want. They are compact.
    Good luck.
    Tom
    rgruppe #111
  1. FS - Badge, 901 Shift Knobs, Short Shift, Dash Switches and more
    By tgittens in forum For Sale: 911 Parts
    Last Post: 02-23-2010, 07:38 AM
  2. Bosch CDI, 400mm Leather Wheel, Shift Light, Distributor
    By 304065 in forum For Sale: 911 Parts
    Last Post: 05-08-2009, 07:35 AM
  3. 915 shift housing with FSS and Gate Shift kit
    By 911pcars in forum For Sale: 911 Parts
    Last Post: 06-11-2008, 11:57 PM
  4. 915 Shift Housing + Gate Shift kit
    Last Post: 06-02-2006, 11:39 AM
  5. FS: 915 Shift housing w/Gate Shift kit
    Last Post: 08-23-2005, 07:51 AM
