Results 1 to 2 of 2
Thread: charging issue...alternator or voltage regulator
    Aug 2005
    VA
    I just installed the alternator after an engine rebuild. problem is it's not producing enough voltage. The red warning light in the dash glows slightly when off idle telling me the car is consuming more power then it is creating. The light goes out when ideling. I had the alternator rebuilt a while ago and replaced the voltage regulator at the same time.
    So, how do I tell if its an alternator problem or voltage regulator problem? The voltage regulator is separate from the alternator.
    Thanks in advance,
    Chris
    73 911 E
    Aug 2005
    VA
    a pic of the back of the alternator
  1. Replies: 11
    Last Post: 09-15-2013, 04:28 AM
  2. Replies: 12
    Last Post: 06-16-2013, 05:07 PM
  3. Voltage regulator problem
    By njhj1052 in forum Technical Info
    Last Post: 08-03-2011, 11:12 AM
  4. '67 911S Alternator Charging Problem - Need Wiring Help
    By Bob Schaefer in forum Technical Info
    Last Post: 12-04-2003, 06:26 AM
