The tachometer on my '71 -E suddenly started jumping around near the end of a nice long drive this past weekend There are multiple threads on several forums concerning this topic, all of which seem to point to voltage regulator, alternator, or grounding issues. Oddly (to me), none of them mention the RPM sensor or RPM transducer. My symptoms are pretty classic - the tach suddenly started bouncing wildly from what seemed about right (3000 RPM), up past 6000 RPM, then down to zero, then up to 6000 RPM again, etc. This continued for the rest of the drive home. Everything else seemed to work fine, including the radio. Unfortunately from a diagnostic standpoint, I started the car up the next morning to check it out, and tachometer behaved normally.
The other piece of information to offer is the alternator warning light goes on dimly at idle speed (around 900 RPM). This has been going on since I bought the car several years ago. It gets progressively brighter as the RPMs go down, and goes out completely at around 1500 RPM and up. I've been meaning to check out both the voltage regulator and alternator (a possible faulty diode ?) due to the warning light, but it hasn't been a top priority since it doesn't seem to affect battery charging and the car otherwise runs fine.
My question for the wiser than me here is: Where should I start first?
1) Obviously, the ground issues are cheapest to fix, but a challenge to be sure you've gotten them all.
2) Batteries are brand-new Sonnenscheins and seem to hold charge well. I use a battery maintainer for extended storage periods.
3) I've been meaning to check out the alternator / voltage regulator combo anyway due to the warning light. This new issue with the flailing tachometer needle gives me increased impetus. Especially if I'm risking an overcharging situation.
4) The voltage regulator is obviously easier to pull than the alternator, but neither is particularly difficult so I'd pull them both to have them tested.
5) I can put a voltmeter on the car to diagnose any low voltages at idle or over-voltages, but it might be difficult to time that with the intermittent tachometer issue. Especially if it doesn't reappear.
Thanks much in advance. Candid advice always appreciated.
- MR
