Thread: Door Panel Welting
    Member JimVillers's Avatar
    Jul 2012
    Virginia Beach, VA
    Door Panel Welting
    I am restoring a 1967 911. I have new door panels and a roll of welting. My question is how to install the welting? Is it installed to the panel with glue before installation? (what kind of glue?) Is it slipped into the gap after the panel is installed? (what hold it in place?) My welting is vinyl and the inside edge of the panel is vinyl/cardboard.
    Jim Villers
    Virginia Beach, VA
    1961 190SL Mercedes, 1965 230SL Mercedes, 1965 356C Porsche, 1971 MGB, 1967 911 Chassis #305119
    Dec 2008
    Woodland Hills, CA
    They were attached using upholstery staples on the back side. When curving the welt at the two bottom corners you have carefully cut a couple of slits on the inner (hidden) portion of the welt so you can get a smooth transition as the welt travels around each corner. Hope this helps.
    Jul 2012
    Virginia Beach, VA
    I need a little clearer explanation. I looked up upholstery staples in google and saw various staples that go into wood frames. Are they shot from the inside or outside and do they go through and then bent flat?
    Jim Villers
    Virginia Beach, VA
    Jul 2012
    Virginia Beach, VA
    Using the clue of upholstery staples, I use my paper stapler in tack mode and it worked well. The staples a small wire, 0.025 inch long; short enough not to protrude through the other side of the door panel. I would have preferred stainless staples but I do not plan for this car to be n the wet and the staples are on the "dry side" of the vapor barrier.
    Thanks.
    Jim Villers
    Virginia Beach, VA
  1. RS Door Panel; Strap Door Opener
    By Captain in forum Technical Info
    Last Post: 03-15-2022, 09:48 AM
  2. Cut Out on Door Panel for Door Pocket?
    By Irish911 in forum Technical Info
    Last Post: 02-17-2014, 05:24 PM
  3. FS: 68 door shells no rust, 67 pass door panel/arm rest, fuch rims
    By scwhite59 in forum For Sale: 911 Parts
    Last Post: 08-14-2013, 04:31 PM
  4. Replies: 2
    Last Post: 03-09-2013, 02:27 PM
  5. Door top bolsters -- upper door panel trim - 69-71
    By Eminence Gris in forum For Sale: 911 Parts
    Last Post: 09-11-2011, 09:13 AM
