Thread: Have you checked your Emulsion Tubes?
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Here's what we found on a couple of F3's while fine tuning the 914-6/GT. Crushed tubes.
    We initially thought someone cranked down on the air correction jets but a quick call to Paul Abbott confirmed that the tubes are plenty deep. Then we ran some digital calipers down the bores... all perfect. All I can think of is; these were damaged in the manufacturing process when they stamped the 3 on the end.
    Some of our undamaged tubes were stamped on the sides. These were stamped on the end... might be worth checking. FYI, this was "very" hard to notice as these are small at about 3/16" at the base. I had to use a special lense on my iPhone to capture the detail. I only noticed it while trying to find the numbers with a large magnifying glass.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    I've seen the end-stamped tubes and there isn't an issue from that. These were hammered to squish them down, I doubt that tightening the air screw would do that and besides, the perpetrator would have needed to put a rod down inside to push against. I think they were hammered to close the holes up, this would effectively increase top end mixture to be richer...easier to solder them shut unless you were short on solder at a speed event and were being resourceful...
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Dec 2002
    Sandy, Utah
    What an odd thing... only two out of 6 so, they must have gotten mixed up in a batch at one time. Thanks Paul...
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
    Banned
    Nov 2004
    Scottsdale, AZ
    I've heard of pinched fallopian tubes but never this.
    So... what were the symptoms? High speed bobble?
    I have never seen a Weber manufactured tube stamped on the end they are always marked on the sides.
    Could it be aftermarket?
    Dec 2002
    Sandy, Utah
    Mine are a mixture of both. Only the end marked ones have the issue and only two out of three of them.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
  1. WANTED - Weber F3 emulsion tubes
    By andyjboy in forum For Sale: 911 Parts
    Last Post: 12-10-2012, 10:07 AM
  2. WTB F3 emulsion tubes for Weber 40's
    By Bill Harris in forum For Sale: 911 Parts
    Last Post: 09-19-2012, 03:36 PM
  3. Weber Emulsion tubes differences
    By 356robo in forum Technical Info
    Last Post: 03-12-2011, 10:56 AM
  4. Weber emulsion tubes
    By 1QuickS in forum Technical Info
    Last Post: 06-28-2010, 09:04 AM
  5. FS - Weber jets and emulsion tubes
    By jj83001 in forum For Sale: 911 Parts
    Last Post: 07-23-2008, 09:11 AM
